hello everyone
Can anyone tell me how to add OP amp 741 to LT spice simulation tool
after downloading and adding to that folder what should i do i couldnot see the LM741 in that opamp folder of LT SPICE DirectiveFafor LTspice IV:
Put the .lib file in C:\Program Files (x86)\LTC\LTspiceIV\lib\sub.
Put the .asy file in C:\Program Files (x86)\LTC\LTspiceIV\lib\sym\Opamps
yes i am using windows 10 and LTSPICE XVIIAre you using LTS version IV or VII? Version VII reads its data from the ....../Documents/LTspice/lib path when using Windows10.
Then put your .lib file in the Users/....../Documents/LTspice XVII/lib/sub folder and put the .asy file in the Users/....../Documents/LTspice XVII/lib/sym/opamps folder.
If you copied the file correctly and scroll through the C:\Users\User\Documents\LTspiceXVII\lib\sym\opamps\ folder you should see it.
thank you sirRemove the quotes characters surrounding the .lib command on the schematic.
i am getting error like can not be open 741.lib even i change to .lib LM741.libHi
Change the statement to:
.lib LM741.lib
Thank you everyone i sorted out my mistakeIn Win10, LTspiceXVII installs the .asy files and the sub files in default (or user-specified) locations, but (as far as I can tell) only reads from shadow copies in folders in the Documents path.
by Jeff Child
