how to add OP amp 741 to LT spice
Status
Not open for further replies.
Alec_t
Joined Sep 17, 2013
15,168
If you copied the file correctly and scroll through the C:\Users\User\Documents\LTspiceXVII\lib\sym\opamps\ folder you should see it.
eetech00
Joined Jun 8, 2013
4,751
Hi
Post #17 is the correct default path for the .asy symbol file.
The correct default path for the .lib file is:
This PC->Documents->Program Files->LTC->LTspiceXVII->lib->sub
The statement shown in post #15 is correct for the default .lib file path.
Alec_t
Joined Sep 17, 2013
15,168
In Win10, LTspiceXVII installs the .asy files and the sub files in default (or user-specified) locations, but (as far as I can tell) only reads from shadow copies in folders in the Documents path.
Status
