How do I adapt twin coil control to control single coil
Brucey30
Joined Jul 3, 2017
36
this has to do model railroad switches (turnout). I have a switch on a panel and it has 3 wires for 2 coils. I the turnout has 2 coils. Energizing on coil turn left. Energizing on the other coil turn right. Works fine. BUT the diffident company railroad turnout I want to use has only 1 coil. And changing the rails left or right by changing the coils polarity by the 2 wires and using same company's controls. I do not want to use company's same controls as maker of turnouts.
I'm thinking there should be a way via diodes or relays this can be done. Note: the coils ONLY get momentarily energized in order to move the rails. How do I do this?
Arnold 7220 turnout controls. ( Want to use)
KATO Uni-Track turnouts I'm using
Thank you
dl324
Joined Mar 30, 2015
18,444
Welcome to AAC!
For those of us how don't know about model trains. How are the LEFT/RIGHT coils triggered?
tcmtech
Joined Nov 4, 2013
2,867
A diode on each coil would do it.
Just wire them up to a common line and put a pair of diodes on the the other line with one facing forward for one coil dn the other facing the opposite for the other.
38,624
Is the switch a center-off and you push it left or right to energize the respective coil?
And you want to use that to drive the single coil in opposite directions, depending upon the direction of the switch press?
Is that correct?
38,624
He is going from two coils to one coil.
Brucey30
Joined Jul 3, 2017
36
Atlas brand model railroad turnouts use 2 coils and 3 wires shown bottom picture . Forgive my lack of artistic abilities. First picture is Arnold brand switch controls I want to use. KATO turnouts reverse polarity to single coil to move rail in direction desired. In the top picture "braun" means brown wire I assume positive ?image.jpegimage.jpeg
Brucey30
Joined Jul 3, 2017
36
Is that correct?
Yes. But the single coil must have polarity reversed to change rail direction
38,624
Here's my take on using your two momentary switches to reverse the direction through the coil using a DPDT relay.
When the Right switch is pressed, the relay is not energized and the current goes through the coil in one direction.
When the Left switch is pressed, the relay is energized and the current goes through the coil in the opposite direction.
Diode D1 blocks the voltage from the Right switch so that only the left switch energizes the relay.
The other diodes are to suppress the inductive spikes from the turnout switch and relay coil inductance so the contacts aren't burnt (is that suppression normally done in model railroad controls?).
The diodes could be replaced by two 1A bridge rectifiers, if you wanted to save on parts count.
Edited to clean up schematic.
yep. Ignore D2, D3, D4 and D5 to see the logic.
In one case, you energize the turn-about in the "standard" direction and in the other, you reverse the polarity as well. D1 isolates the right from the left switch.
Nice!
strantor
Joined Oct 3, 2010
6,875
diodes in series with each coil.
diode + coil pairs wired in parallel.
When you apply polarity in 1 direction, coil1 is energized.
When you apply the opposite polarity, coil2 is energized.
38,624
There's only one track switch coil in the new design.
38,624
Here's a solid-state approach using a simple MOSFET bridge.
The MOSFET substrate diodes provide suppression of the load inductive spikes, so separate diodes are not needed..
Brucey30
Joined Jul 3, 2017
36
First. Thank You for replying. I've dabbled very little in electronics and know very little. Am I looking at 2 or 4 MOSFETs? I can understand "how" to hook them up once I understand completely
Alec_t
Joined Sep 17, 2013
15,145
This might be worth a try. The cap value needed would depend on the turnout coil characteristics. I assumed a 24 Ohm coil for the sim.
Edit:
This relies on the switch not being a momentary type.
djsfantasi
Joined Apr 11, 2010
9,237
Ok, you are using a SPDT switch inline with a momentary pushbutton to activate whatever coil is set by the switch position. This is how I understand your 2 coil setup as I have Atlas switches myself.
Now for the 1 coil solution. Replace the SPDT switch with a DPDT switch. Wire the switch as if it was a reversing switch. Now the two wires from the DPDT common terminals go to the coil. The outside contacts are connected to the switch power. You can connect to either end, but remember you want that the primary route should be the same switch position.
No diodes. No MOSFETS. Just wiring
