Hypatia's Protege
- Joined Mar 1, 2015
- 3,228
DOH! Got it!
PCB P/N= HT111A1 --- I'll see what I can find
Best regards
HP
Best regards
HP
Before you go too far down this path I suggest testing what your LED looks like when supplied your full budget of energy, 60 microwatts or whatever. You cannot expect your machine to do any better and in fact it’s probably losing half or more of the energy. You’re only getting flashes now because your machine - by design- feeds the LED a very low duty cycle, perhaps 1% or less. If you try to achieve a higher duty cycle, you’ll smooth out the pulses to a very dim glow.I wish a led which is not blinking - Dc current - I am thinking to add some small neo magnets
True enough! -- Though I daresay (series connection of) a low E[bo] Diac would help thatA LED has no negative resistance characteristic
