Help please Electrolux freezer
Dano41
Joined Aug 1, 2016
42
electrolux circuit board.2.jpeg Hi,there was a power outage at our house the other day when it came on our freezer didn't power up.There is power coming to the board but it is not working.I have to wait at least two weeks to get a replacement board.Have done electrics but my knowledge of electronics is minimal.If it was a power surge that damaged the board is there any protection which would be built into the board and could be replaced or does the board just get fried.Any help with this would be greatly appreciated.View attachment 173166
drc_567
Joined Dec 29, 2008
1,156
There seems to be a blue lozenge shaped part adjacent to C14. The label seems to say Vxxx? Could that blue lozenge be a transient voltage supressor of some kind? ... Had one if those take out a garage door opener after a near-lightening strike ... just replaced the whole board though. ... It might be interesting to see if there is power on both terminals of the blue capsule looking part.
Ya’akov
Joined Jan 27, 2019
10,370
Barring obvious "skid marks" (burnt comments, you'll need to trace the circuit and find where things stop working. drawing a schematic to help you follow signal flow from the power input to where it fails.
wayneh
Joined Sep 9, 2010
18,184
Sorry did mean capacitor.The diode does not separate.
I just want to be sure we don't miss this - that cap looks suspicious from the top view but of course it's hard to tell. Even a slight bulge would be cause for replacement. Hell, random replacement of all the electrolytic caps isn't a bad idea. I know it sounds crazy but sooooo many board failures are due to failed capacitors. Caps can fail on ESR with no visual clue. Just replacing them is likely to extend the life of the board and it saves a lot of diagnostic time.
