help me with LTspice command.
Lija
Joined Nov 13, 2020
6
Hi!
Is there anyone here who can help me with LTspice command. (MacBook Air) I'm drawing a nonplanar circuit. And can't figure out how to get the components to connect on the diagonal lines. Skjermbilde 2020-11-13 kl. 17.05.42.png
38,516
Why can't you connect them the same way you connected the other components?
There will be a jog in the diagonal wires where the resistors are connected, but that doesn't affect the circuit simulation (see examples below):
The components rotate in 90° steps, and I don't know of any way to rotate them to the same angle as the wires.
eetech00
Joined Jun 8, 2013
4,705
Hi!
Is there anyone here who can help me with LTspice command. (MacBook Air) I'm drawing a nonplanar circuit. And can't figure out how to get the components to connect on the diagonal lines. View attachment 222165
Components will only rotate in 90 degree increments, so you'll have to use the drag tool (closed hand icon) to drag and bend the wires until they connect to the pin.
Papabravo
Joined Feb 24, 2006
22,082
View attachment 222176View attachment 222175
You can take the coordinates from the resistor symbol, rotate them 45°, and voilà you have a new resistor symbol. It may look a bit different than you expect because you are working on a grid with integer coordinates and some rounding will inevitably take place. Here is the diode symbol I use for doing bridge rectifiers.
Lija
Joined Nov 13, 2020
6
Thank you for the respons. LTspice is a new thing for me as student.
I had an expectation of getting straight lines dioginally when I pulled the wires in the circuit. So I got a little
frustrated when I saw that I did not get it.
Lija
Joined Nov 13, 2020
6
Thank you for the tips!
