help me control mosfet PAO4614
AKFD
Joined Apr 14, 2025
65
hi ericgibbs
Could you please check if there's any problem with this circuit?
Is diode D1 protecting the gate correct or incorrect?
What is the value of R5?
AKFD
Joined Apr 14, 2025
65
hi ericgibbs
Can I replace a P-type MOSFET with an N-type MOSFET? I noticed the IR2110 controller circuit only uses N-type MOSFETs.
ericgibbs
Joined Jan 29, 2010
21,559
hi AK,
The problem when using a NMOS as a Source Follower circuit, is that the Vgs voltage is limited by the voltage drop across the Source Load, so the Vsource voltage can never be 24V.
E
AKFD
Joined Apr 14, 2025
65
Chào ericgibbs
Vậy là không còn cách nào khác để kết nối chúng, đúng không? Vậy thì chúng ta phải dùng MOSFET loại P, phải không?
Mod: translated.
Hi ericgibbs
So there's no other way to connect them, right? Then we have to use P-type MOSFETs, right?
ericgibbs
Joined Jan 29, 2010
21,559
hi AK,
If one end of the 8R load must be connected to 0V, then a PMOS is the best solution that will give a full 24V swing across the 8R load.
E
Nếu một đầu của tải 8R phải được nối với 0V, thì PMOS là giải pháp tốt nhất, nó sẽ cung cấp điện áp dao động đầy đủ 24V trên tải 8R.
AKFD
Joined Apr 14, 2025
65
hi ericgibbs
Does diode D1 have gate protection for the MOSFET? Is it okay to remove diode D1?
Because R4 and R1 divide the voltage to 12V.
AKFD
Joined Apr 14, 2025
65
hi ericgibbs
I tested turning off the input signal to 0V. I see the gate MOSFET P pulling up to 24V.
So, is there anything wrong with the P MOSFET? Is the P MOSFET damaged?
ericgibbs
Joined Jan 29, 2010
21,559
hi AK,
The VGate to VSource voltage is Zero volts, the PMOS is Off, non Conducting
E
Added: Is this project a Homework or College assignment.??
