help me control mosfet PAO4614
AKFD
Joined Apr 14, 2025
42
Am I testing this circuit correctly? 100KHZ D=50%
if i make real circuit like simulation is ok? 100KHZ or 50KHZ D=50%
Why is the pulse skewed?how to make it balance again D=50%?
Ian0
Joined Aug 7, 2020
13,228
Two more reasons it could be skewed:
Bipolar transistors take longer to switch off from saturation than to switch on, that’s why we use the anti saturation clamp.
The switch-on impedance is 50Ω, but the switch-off impedance is 100Ω, so the gate capacitance charges in half the time it takes to discharge.
but @ericgibbs ’s answer seems the most likely.
AKFD
Joined Apr 14, 2025
42
If you are satisfied with 3Watt losses….You can use a simulator with real transistors models like LTspice, etc..
It will show you the delay between input pulse (from Mcu) and load current. I prefer the delay to be less than 1/20 of pulse width, but some folks may have no problem with 1/10.
In numbers:
If pulse width is 20us i tolerate a 1us delay.
Also the simulator shows you the mosfet turning off transition, how much switching losses on mosfet you can expect.
Roughly, from my practice with 100 ohms in gate you can go up to 10khz.
I simulated it using LTSpice.Please check if it's okay?
I tested at a frequency of 100kHz.
AKFD
Joined Apr 14, 2025
42
At a glance, the main issue is that the push-pull BJTs (Q11/Q10) feeding the MOSFET gate don’t have a clear, well-defined bias path, so the MOSFET gate may float or switch slowly. The zener (D7) can also clamp too high/too low depending on your intended gate voltage, and R19 = 47 k is far too large for fast or reliable gate pull-up.
If you say what function you expect (level-shift? constant current? soft-start?), I can point out the exact fixes.
constant current
AKFD
Joined Apr 14, 2025
42
hi ericgibbs
there is small difference on the 50/50% period on the output
How to achieve a 50/50 balance without being skewed?
ericgibbs
Joined Jan 29, 2010
21,533
hi AK,
This is one method for this circuit, in an actual circuit it would require an S.O.T. [ select on test] selection of one or two of the added components in order to ensure 50/50%.
Please post a complete specification for the project.
E
AKFD
Joined Apr 14, 2025
42
hi ericgibbs
The circuit you described works well at 100kHz but not at 50Hz. why?
I need it to work at all frequencies. or slow on and off
ericgibbs
Joined Jan 29, 2010
21,533
hi AK.
Are you trying to build a universal circuit that will operate on frequencies of 50Hz through to 100kHz and also have a variable Mark/Space ratio over that full frequency range???
What is the purpose/application of this circuit, how will it be used??
E
This a 50Hz version, note the value of C1 capacitor.
As I posted earlier, some components will require selection for a particular frequency
AKFD
Joined Apr 14, 2025
42
hi AK,
I am sorry, but I do not understand why you are asking for a 50Hz through 100kHz pulse generator, when you are using a 500Hz scanning frequency.??
E
if(TScanled >= 2)
Select_7SEG4_B(0,0,0,0,0,0,0);
delay_us(3); // dead-time 3us
// 2. Gui du lieu
STCP = 0;
Shift_Out_74HC595(buffer[0]);
Shift_Out_74HC595(buffer[1]);
Shift_Out_74HC595(buffer[2]);
Shift_Out_74HC595(buffer[3]);
STCP = 1;
switch(Scanled)
case 0: Select_7SEG4_B(1,0,0,0,0,0,0); break;
case 1: Select_7SEG4_B(0,1,0,0,0,0,0); break;
case 2: Select_7SEG4_B(0,0,1,0,0,0,0); break;
case 3: Select_7SEG4_B(0,0,0,1,0,0,0); break;
case 4: Select_7SEG4_B(0,0,0,0,1,0,0); break;
case 5: Select_7SEG4_B(0,0,0,0,0,1,0); break;
case 6: Select_7SEG4_B(0,0,0,0,0,0,1); break;
delay_us(150);
Scanled++;
if(Scanled >= 7) Scanled = 0;
TScanled = 0;
Select_7SEG4_B(0,0,0,0,0,0,0); anti-ghosting
delay_us(3); // dead-time 3us->20us
If the circuit is stable, we can later create an H-bridge circuit to control the motor.
ericgibbs
Joined Jan 29, 2010
21,533
hi AK,
Check the output MOSFET's Gate to Source voltage, the lower plot. [ V(5v,N001]
The Gate drive is incorrect for a 24V output swing.
E
