Help about varible constant current
Dzoro
Joined Feb 1, 2019
194
If you are referring to just my circuit, yes, the output will be essentially equal to the supply voltage until, the current limit is reached.
Where do you have the current pot set?
If it's set at zero, you will have zero output current.
No they are not additional transistors.
They are the ones in the voltage regulator circuit.
Sorry I didn't make that clear.
That's why is not working beacose i used other 2 transistors beacose you didn't say that it needs to conect to the auditional transistors
Can you combine the 2 circuits and send me the final circuit so i cqn build it simply
I am lost with the design so pls help
38,747
Below are the two circuits.
Output of U1 goes to the collector of Q2.
The two node 1's are connected together.
The two V+ are connected together.
Make sense?
AnalogKid
Joined Aug 1, 2013
12,256
Sorry, I just found another glitch. :oops:
The LM358 doesn't pull the output to all the way to zero when the output is shorted, so the current is not limited under those conditions.
Hmmm ... The 3055 Vbe isn't exactly tiny to start with. With two of them in series, and one of those increased by the large collector current, I would think a 358 output could get close enough to GND to starve them. Especially since the 358 GND is on the other side of the current sense shunt, another 0.4 V below the output emitter in a dead short. Just wonderin ...
ak
AnalogKid
Joined Aug 1, 2013
12,256
I'm curious, what does you sim show the 358 output current to be at that point? Part of the 358's fame is its ability to pull a valid TTL low, so my guess is that the current is relatively high. According to the datasheet, north of 10 mA.
ak
Dzoro
Joined Feb 1, 2019
194
Make sense?
View attachment 174519View attachment 174520
And now you are saying that the output of the comarator is going to q2 and in the previous circuit you say that the invering pin is to q2 colectors pin and that the output pin from the comparator goes to the base of the 2n3055.And you didn't say that the circuit is going before the voltage contoler.I AM SO CONFUSED RIRIGHT NOW.
Dzoro
Joined Feb 1, 2019
194
ak
It's not using 358 it's using 339
38,747
Here are two identical simulations except the first uses the 358 and the second used the 339.
As you can see, the 358 output goes to a minimum of 1.3V when trying to unsuccessfully limit the current to zero, whereas the 339 goes down to 900mV, limiting the current to 5mA.
Dzoro
Joined Feb 1, 2019
194
And what abot the conections that are different in every circuit that you sent
38,747
I always said the comparator output goes to Q2's collector, which is the correct connection.
When I said it goes to Q2, I meant Q2's collector.
I'm sorry if the previous statements confused you.
Just follow my last schematic in post #22.
It shows the comparator output going to Q2's collector.
Do you understand those connections?
Dzoro
Joined Feb 1, 2019
194
20190408_020228.jpg And in this circuit the output is going to the 2n3055 and the negative input of the comparator is going to the q2 so that is why ia am confused about.Do i have a conection to the big 2n3055 transistor or just to bc547 colector
38,747
That discussion is between AK and myself.
If you don't understand it, you can ignore it.
The only circuit you need to use is the one in post #22.
Where do you see that?
None of my circuits show a direct connection to the 2N3055.
You seem to have difficulty following schematics. :rolleyes:
Dzoro
Joined Feb 1, 2019
194
that one that i sent you is directly conected between the output of the comparator and the base of the 2n3055.Its obviusly direct conection as you can see
38,747
It is not "obviously".
I see a resistor in series with the 2N3055 base.
That's not a "direct connection".
And please stop referring to other previous posts.
Please confine your schematic questions to the post #22 schematic.
Otherwise I'm out of here.
Dzoro
Joined Feb 1, 2019
194
I am going to try the circuit and give you feedback
Dzoro
Joined Feb 1, 2019
194
It's not working i can ajust the current from 1 mA to 23mA and the voltage is not going more than 7 volts
