panic mode
- Joined Oct 10, 2011
- 5,141
probably transistor got smoked too. you stated that supply voltage is 12V. how stable and precise is this 12V supply? IC1 true goes to supply rail so Vgs can be 12V. datasheet for si4466dy shows that 12V is the absolute max for Vgs. you should never allow that for this transistor. this one is meant to be triggered by much less such as 2.5V or 5V. I would not like to see anything over 10V at the gate but your circuit has nothing to keep the Vgs at safe level. the replacement also works with low Vgs but it is more robust and can survive Vgs up to 20V. Do you read datasheets? They are your best friends.
also not sure what made you draw a conclusion that IC did not work. how did you test it?
did you check important points with an oscilloscope? how about an output of the oscillator? if i am not mistaken that is pin4 (output of IC1b). this pin should be always toggling and you should be always able to change duty cycle using potentiometer - regardless of delay or state of the transistor. you can add an LED and resistor to PIN4 to see if it works. LED brightness will change when PWM duty cycle is adjusted. if you put larger cap on pin 5, you will see the LED flicker. that is one stage.
another stage is delay circuit. another stage is pair of gates driving transistor. finally you have a transistor. each stage can and should be checked. I know you are probably aiming for minimal part count design but things could also be added temporarily while troubleshooting. what kind of tools you have at your disposal?
