Hello, why is circuit not working?
ElectricSpidey
Joined Dec 2, 2017
3,356
You can place all of the resistors you want in series with a MOSFET gate, but it won't prevent the gate from charging to the applied voltage.
The proper way to limit the gate voltage is usually done with a "clamp" or a divider.
A gate resistor and a pull resistor can form a divider.
Fady.Soliman
Joined Jan 20, 2023
44
A small series gate resistor is to eliminate possible MOSFET oscillations, not to protect the gate.
I don't think that's a problem here, but you can add one if you like.
Since the gate will never be floating on the PCB, I see no reason to add a pull-down resistor.
Thank you for your reply. I think I will add the gate resistor just in case, does 1k Ohm sound good enough? would the 1k ohm effect the pwm speed much (frequency)? Do you suggest another value?
For the pull-down resistor, I agree with the PCB there should be no floating with the gate.
Appreciate your input and help.
Fady
Fady.Soliman
Joined Jan 20, 2023
44
Thank you ElectricSpidey for your reply.
Yes the gate resistor and the pull resistor would act as a divider. But actually I don't think I will need the pull resistor as crutschow mentioned in the case of the PCB. I think I will only add the gate resistor to prevent the mosfet oscillation. As for the mosfet gate it is supposedly rated at 20V so fingers crossed the 12V wouldn't be a problem for it.
Thank you.
Fady
38,683
I don't see that 12V it too high for a 20V rated gate voltage, which is derating to 60% of the max.
Typically 10V is applied to fully turn a standard MOSFET fully on.
For eliminating oscillations 10-100Ω is typically used.
1kΩ could reduce the rise and fall time, increasing the transistor dissipation.
ElectricSpidey
Joined Dec 2, 2017
3,356
Neither do I...so what is your point?
I was just providing general purpose information to counter the idea that a series resistor can protect a MOSFET gate.
What is your problem, anyway?
Fady.Soliman
Joined Jan 20, 2023
44
Hello crutschow,
Thank you for the explanation. I will use the gate resistor for the oscillation with the value 100Ohm. I will finalize the PCB and hopefully have it soon. I will keep you posted about the out come.
Thank you again for all the help.
Fady
Fady.Soliman
Joined Jan 20, 2023
44
Hello @crutschow
It has been a while but I finally got he circuit made and the results are rather interesting. So I decided to make the circuit using a moset called " KIA50N03BD" since it was what's available and at a good price. When I tested the circuit the output went first full voltage (12v) and then went to 7V (it is supposed to go to 3.3V). The mosfet gets super hot almost instantly even tho it is supposed to be able to handle 50AMP (the load is around 2 or 2.5 AMP). I decided to change the mosfet to another mosfet I had "IRF3205" and to my surprise the circuit worked as it is supposed to with no issues!
My question is, aren't all N-channel mosfets created equal? In the sense of, both mosfets are capable of handling more than needed in terms of AMP and drain to source voltage. Why are they acting differently in the circuit.
I would really appreciate your help since curiosity is killing me!
Thank you in advance.
Fady
