Jon Chandler
- Joined Jun 12, 2008
- 1,645
There are many devices in SOT-23 packages including voltage regulators marked A7.
This table lists some of them.
Ok which leds does it fade out, or it might be feeding the backpane voltage, it might be a transistor see if you can test it with a multimeter to work out if it's a npn or pnp or fet.ok permission to call me a idiot. I'm surprised the manufacturer hadn't picked up on this also.
So been looking again at other chips surrounding the SRAM to ensure no other resistors etc are actually causing the problem rather than the SRAM. The yellow chips to the left of the SRAM I've tested before, and just to be sure I tested them again this morning by applying heat to them with a soldering iron and they do not affect the display what so ever.
However.... what I had not noticed is that there is a very small chip on the opposite side of the board, almost directly behind the SRAM chip. See 1st and 2nd pics attached. This is what is actually causing the problem, not the SRAM chip. If I apply heat to this chip with the soldering iron the text on the display immediately goes blank.
So what has been happening during our tests is, when we heat the SRAM chip, the heat is transferring to the board and also heating this small chip located nearby on the opposite side of the board. And when we're cooling the SRAM chip and seeing the display quickly restore, it is also cooling the board and again also the chip on the opposite side of the board. So it made it appear that the SRAM chip is causing the problem when in fact it's this small chip on the opposite side.
If I remove the chip completely the contrast of the display is badly affected. See 3rd pic attached (ignore the vertical black lines, this is the problem the old original displays have due to delamination of the ribbon cable joint which I mentioned earlier in my previous post - this is why I've had the new displays made).
As a test, what I've done is removed the chip from the board, and then installed 3 wires from the board to the chip so that the board can be heat tested with the chip away from it. Now if I apply heat to the SRAM chip, it has no affect what so ever to the display (I tested by applying heat to the SRAM chip for 4 minutes with the soldering iron with no problems). If I apply heat to this chip with the soldering iron it immediately causes the text to fade and disappear from the display.
See my video here:
I cannot believe I didn't spot this small chip and test it earlier!
It looks like this chip is a switching diode? The marking on it is A7. So now my question is, what can be done to prevent this chip from causing my problem?
My thought is your now on the right track.I've just checked several other of these instrument cluster boards I have here and they have slightly different codes for this chip. Some are A7, some are A7S and some are A7W.
Totaly agreeRather then some screwy change in a memory chip, isn't it much more likely that the LCD contrast voltage needs to vary with temperature?
Yes I agree ."If the display "fades out" , then I was thinking how could a sram cause this .
if it was heat of the sram, then then digital data out of the sram would have to change to cause this effect,
digital data does not tend to be "fade" its either there or not. and tends to be on pixel basis not per display
also it does not "return" when heat is removed. "
Here's how, if the SRAM is a display buffer contains 8-bit pixel intensity values and say an output driver does bad, then one bit goes stuck at zero. All values are reduced by the bits value (i.e. 1,2,4,8,16,32,64.128) resulting in an overall reduction in intensity.
Only "screwy" if you don't know what you're doing or what's possible.
Yes, that would be a 1-bit pixel and is a possible solution.At the risk of being ridiculed again, I must ask another stupid question.
Would not an LCD of this era be strictly a monochrome device? And each bit of the image array turning a pixel on or off? BIT, not BYTE? In which case, corrupt data in SRAM could only result in missing or extra pixels?
To highlighWhat a brilliant thread.
just like a ‘who done it‘ with the last page missing.
Looks like the BAV99 is connected to the contrast control for the lcd.
Typically the contrast control is set at a particular voltage level to give the best contrast and may be fixed or in some instances may have a temperature compensation scheme to ensure that the display remains legible as the temperature varies.
Whichever scheme is used it is important that this bias voltage remains within fairly tight limits and for the temperature compensation to work properly the sensing device must see the same temperature as the lcd.
If for instance the Vf (forward voltage) of the two diodes of the BAV99 are in some way being used to control the contrast voltage of the lcd then heating the BAV99 and not the lcd will cause a change in the contrast control voltage and a corresponding change in lcd contrast. In your case the contrast is drastically lowered.
Another possibility is that the BAV99 is being used in its more traditional role as a protection device on the lcd contrast control and that the increase in leakage current caused by heating it is changing the lcd contrast voltage and causing the issue.
If it is a protection device then it can be removed without affecting the lcd for test purposes.
The table I linked in post #41 lists many possibilities for an A7 top mark: dual diodes, linear voltage regulators, P-channel mosfets, NPN transistors to name a few.We are guessing the 3 pin device is a bav99. There are a good few other parts with the same markings , for instance ldos .
Hi @Jon ChandlerThe table I linked in post #41 lists many possibilities for an A7 top mark: dual diodes, linear voltage regulators, P-channel mosfets, NPN transistors to name a few.
I am pretty sure I have some A7-marked components in .my collection, but I can't remember which part it is.
A dual-diode seems to make the least sense in this case. If you can trace the connections, that may provide some clues. Connections to power rails, capacitors in parallel or resistors in series or parallel will provide some ideas what the part is.
Is there any way you can find the schematic or BOM of this thing?Thanks for all the replies. I'm currently away this weekend so will have a proper read over these next week. Thanks for all the input.
I done another test this morning with heat. So I've identified it is definitely 100% this A7 chip which is causing my problems with the text disappearing from the display when the instrument cluster gets hot. What I've done to confirm this is remove the A7 chip from the board, and connect it via 3 wires between the board and the chip, that way I can place the A7 chip away from the board when testing with heat (as mentioned in my previous post). So now, when I apply heat all over the instrument cluster's board (with the A7 chip placed away from the board so it remains cool) the display continues to work absolutely fine regardless of how much heat I apply to the board. I tested a good 5 minutes with the hair dryer at full heat and the display worked absolutely fine throughout (normally with the A7 chip fitted on the board the text on the display would fade away and disappear completely within 10 seconds of doing this test).
Now if I apply heat to the A7 chip only (again whilst the chip is away from the board connected via 3 wires), the text on the display quickly disappears if I apply 100oc or more to it with a soldering iron (I have a soldering workstation that allows me to set the temperature between 100oc and 500oc. As soon as I remove the soldering iron from the A7 chip the display very quickly restores to working as it should.
So it is definitely the A7 chip which is causing my problem for sure.
Just to clarify some points:
- this is a problem which has been there with these instrument clusters from day 1 sinc
I believe you are correct in that this A7 chip is connected to the contrast control for the LCD. If I remove the chip, the contrast of the display is heavily affected and the display flickers slightly.What a brilliant thread.
Unfortunately not. The vehicle manufacturer MG Rover closed down in 2005, so the schematics of the instrument cluster just cannot be found anywhere.Is there any way you can find the schematic or BOM of this thing?
