If removing the sot23 device heavily affects the contrast then it would seem reasonable to assume that the device could be in series with the contrast control input to the lcd. You also state that the display flickers when the sot23 device is removed. Could this be due to the contrast control pin floating with the sot23 device removed which is causing the voltage at that pin to vary and the contrast to vary?
The most common scheme for adjusting the contrast of lcd displays is a simple potentiometer connected between Vcc and 0v with the wiper supplying the contrast bias voltage, usually labelled VO.
Lcds with wide temperature specs often require a more sophisticated method of contrast control to guarantee legibility over their operating temperature range. This normally means including traditional temperature sensing devices such as thermistors with an amplification stage to adjust the contrast voltage to keep the display legible as the lcd contrast parameters change with temperature.
If this issue has been happening with all of these modules then it would seem that the design of the contrast control scheme is suspect. Has there been a change in the type of lcd fitted?
Was this contrast control appropriate for another, maybe earlier, series of lcds?
