guys i think something wrong with my multimeter
Muhammed Fatih Saruhan
Joined Jun 22, 2019
11
i dont know why but my multimeter shows higher value when measuring after a diode why is that ? here is video about it
and multimeter is new i just bought it please help
danadak
Joined Mar 10, 2018
4,057
im expecting lower voltage after diode because as far as i know diode drops supply voltage from 0.5 to 1 volt am i wrong?
If diode is conducting that is its forward drop. But if your meter presents very high Z
load then diode has no current thru it.
Regards, Dana.​
Dodgydave
Joined Jun 22, 2012
11,395
" Relative" cancels out any stray pick up voltage on the leads, so your meter reads just the voltage difference on the leads.
AlbertHall
Joined Jun 4, 2014
12,640
Don't think so.
Say you connect the meter to a battery then press the relative button. I would expect the meter to show zero. Then connect a load to the battery and as the battery voltage falls the meter would indicate a negative voltage being the amount the voltage is now less than the original measurement. So the meter indicates the voltage relative to the reading when the button was pressed.
Joined Jun 22, 2019
11
If the current thru the diode is 0 on the graph what is its V ?
The upper right hand quadrant of graph is when the diode is
forward conducting, the 3'rd quadrant is when the diode is in
breakdown, usually destructive if current not limited.
Regards, Dana.
so its normal if its showing more voltage then power supply when not connected to a load ? if so why is it normal now its showing lower voltage now after remove battery and connect it back
Dodgydave
Joined Jun 22, 2012
11,395
Don't think so.
That's what my meter does, it cancels out any stray pickup on the leads.
danadak
Joined Mar 10, 2018
4,057
If leads not connected to anything, the meter will autorange to
more sensitive scale, and pick up induced V from mains wiring
in building. Fluorescent lighting a big contributor to induced V.
Not sure on second question.
Regards, Dana.
Joined Jun 22, 2019
11
Regards, Dana.
but after i take battery and put it back on now its showing less voltage when diode is not connected anything
danadak
Joined Mar 10, 2018
4,057
If you short leads together what does it read ?
If you place leads on bench, without touching them, what does it read ?
The two leads not touching each other.
Regards, Dana.
