Hi all
New here! I am looking to convert my broken LED display into a skylight, something like DIY Perks youtube videos. I was able to disassemble the display and get the lens layers and broken panel off. But i am unable to figure out exactly how to bypass the signal detection stage of the monitor itself so as to avoid it from hitting standby mode. Being a PC monitor, it tends to go into standby if there is no signal detected through any of its inputs (HDMI and VGA). The youtube video i referenced used a laptop screen which had a PWM and LED_EN point on the PCB which he connected to the power supply using a couple of 180 Ohm resistors. In another video he used a TV with the fresnel lenses on but the LEDs he used were stick on type strip LED. What i was hoping to do is use the existing circuit and power supply and just bypass the signal detection so the lights stay on. Is there a way to do it or is it just an exercise in futility? Another video i came across was from Marcus Fuller where he uses an old TV, but only removed the TV circuit board and bypassed the circuit tricking the mainboard. Something similar is what i hope to achieve. Any help i can get is much appreciated.
The monitor I am using is a Viewsonic VX2776 SMHD. Attaching an image of the circuit board though i understand that just looking at the image of the board may not be enough to solve this.
Just wanted to say i am very new to electronics and only have a basic understanding in hobbyist or enthusiast electronics and electrical work.
~Regards
Sam
~Regards
Sam
