That should be fine I think.... I used 24awg and what looks like 26-30 feet.
That's a valid point, although in this case the motor only needs low speeds. CMOS gate outputs should drive FETs easily up into the 20kHz range, which with this motor would be a speed of 10000 RPS or 600000(!) RPM.Praondevou said:...
Edit: something else I just saw. The current for the gate charge of the MOSFETs comes from the CMOS gate outputs. They cannot provide very much current which will slow down the FET gate charge, it will possibly also cause an increased power dissipation in the CMOS gate output stages, although I cannot say to what degree. In other words, this also puts a limit to the maximum rotational speed.
This is why it takes much longer to invent anything by yourself than when you are working in a team! A resistor, of course!.All you need to do is put a resistor in series with each coil pair to limit max current to a safe level (like say 300mA). At 12v the resistor might be about 47 ohms, and you should use 5W resistors as they will get a bit hot.
That will be an easy solution to set a fixed coil current when testing, and might be all the solution you need in the final device.
You cannot pass 5Amps through 30AWG for more than a few seconds.by using ohms law and that website to calculate wire resistance in 30 awg wire, with power source of 13 volts (I turned to 13.02v) and a desired 5 amps, I would need 2.6 ohms total resistance.
If you could choose your wire gauge and number of turns so that you stay at 1 or maybe 2A at most that would be great.oh. but then the amp rating for 30 gauge wire is a little less then 1 amp...
back to square one.
looks like resistors are still the answer.Good idea to use sockets.
The necessary wattage of the resistors you can simply calculate with V*V / R. Current is pulsed so if you just take this value it's ok.
Yes. That's big, isn't it?looks like resistors are still the answer.
ideally I need 13 ohms at 13 volts to give me 1 amp.
by your calculation I would need resistors rated at 13 watts. is that correct?
Great!This will be fun to experiment with, my daughter is really taking an interest in this, so we'll be able to experiment and spend quality time together. Win Win!
Not at all. If you want, say 1 amp, then just set the current limit for one amp. If you want two amps, set it for two amps, etc. You can use your current limit without resistors to determine what current is needed to get the required field strength. Just be careful and don't set the limit too high, and burn up your coils.Good point, however to determine if the magnetic field will be strong enough to make the rotor turn with the coils I have, I will need 13 watt resistors so that the power supply doesn't go to a fail safe and cut the voltage. ahh what a conundrum...![]()
They are not polarized. You can put them either way.quick question: for the ceramic capacitors 100pF and 100 nF, how do I determine + and - ?
or does it matter how it goes into the circuit?
Yes. If you are not sure you can post a picture.thanks. and the polarized ones are marked with the negative lead having the stripe or - on it. right?
| Thread starter | Similar threads | Forum | Replies | Date |
Neodymium magnet Vs electro magnet strength. | General Electronics Chat | 11 | |
| B | electro magnet help and advice | Technical Repair | 21 | |
| L | cricut electro magnet | General Electronics Chat | 3 | |
| A | I need reversable DC pulse electro magnet driver | General Electronics Chat | 3 | |
| C | Electro magnet alternating circuit | General Electronics Chat | 15 |
