I have been tinkering around with that, and think that I will use a magnetic bar, like the ones that chemist use in their stirrers and attach that to a center shaft that will be held by a bearing, I have everything that I need I just need to put it all together.@JCOX - While waiting on your parts and final circuit, here is something else to consider/work on. You will need a way to hold your magnet and allow it to spin. I'm pretty sure that just laying a magnet on the top plate of the 'project' is going to make it spin when power is applied.
A rotating motor of any type needs a central shaft, to keep the rotor(magnet in this case) from being thrown out of the stators/fields rotating magnetic force. With out a pivot point it is going to attract the magnet to the most powerful coil and stop rotating. And with hand wound coils one of them is bound to be stronger than others. Just something to think about.
Honestly that was something that I wanted to incorporate, it's not necessary at all. It definitely isn't going to transfer over to the lesson. If everything works out, and I don't screw anything up, I want to make one for myself just to play around with and the random thing is going to be fun to play around with.@Prandevou, I must of missed something in this thread, or maybe it was in a PM with you and JCOX.- Why a random voltage generation for the 555? I thought this was to simulate what is happening in a electric motor? Sorry for asking such a dumb question, but I'm lost now.![]()
I'm almost 40 years old and this stuff excites and interests me!!
