I rewound those 2 coils with 64 feet of 30 gauge wire each and when I turned on the power supply it didn't go into the fail safe mode, it produced a pretty strong magnet too, however I only had it on for roughly 5 seconds before I turned it off, I had the voltmeter held on the terminals and it held at 13 volts. (I'm about to go off memory here so bare with me ) the total resistance for the 2 coils (in parallel) is 3.7 ohms which by doing the math is still 3.5 amps ( I tested it with the ammeter and verified it was 3.1~), still too much, I really want to get it down to less than 1.5 (like you suggested) So with my new found information I'm going to calculate the resistance and wattage needed to get the proper current flow.
Question: Can I turn the power supply down to 11 V and still have the logic portion work correctly? or is the circuit pretty much set for 13 V? The reason why I ask is by turning down the voltage, I wouldn't need as big of resistors.
Other news: I am almost done with soldering the board, I have all the components on there and I have about half of the jumper wires done on the backside. Let me first say, I should’ve used a bigger board but if this works and there’s a next time, I will opt for a much larger circuit board.
Once everything is wired, I will look it over with a magnifying glass to spot any possible shorts and then I will do a battery of continuity tests to confirm proper connection.
After that I will be asking for your help to hook it up to power and then start testing the logic side with the multimeter (before the magnetic coils are hooked up) so that I can dial in the trim pots to the right settings. I haven’t given up on acquiring an oscilloscope, all my leads have ran dry but I have people looking still.
J.
P.S. Should I request this thread to be moved into the project forum?
J.
