It doesn't need to be 10nF. That's a commonly used value. I guess any mid sized cap will work, possibly even no cap at all.I connected the logic portion to the random and started running the tests. first the output (pin 3) and it was moving from 0v to 12v. because I am unable to shut the random off its difficult to see any consistent results. I have to pull a 10 nF off of the other board to remove the random portion from the equation. unless you have another way to do it with uF caps...
Yes, for the noise you are seeing 0.1uF is good. Maybe add a 220uF between the power supply + and - as well if there isn't already a larger cap on the power rails.I have an extra 100 nF... that will work right?
Yes it oscillates.Heres a snapshot of it at the lower voltage:
It jumps all around huh??
Thanks for that . That's what I expected.and for fear of going to 0 ohms I stopped close and here's a screen shot of the randomness:
so that oscillation is a big concern huh?I'll check this tomorrow if nobody comes up with a solution.
You could use only two probes and measure one after another, i.e. 1 with 2, 1, with 3, 1 with 4 etc, then 2 with 3, 2 with 4 etc and so on.I didn't do much after lunch today. tomorrow I will add that capacitor and switch so that I can turn off the random portion. when I test the outputs of the 4017 to ensure that only 1 is on at any given time, I need to devise a way to probe all the outputs 4 at a time. I was thinking of sticking pins inside the sockets of all the outputs. what do you think?
Not ANY other transistor, only this transistor pair. The same signal is turning one FET on and the other one off. The source terminals of both transistors are tied to the power supply rails, one to + the other to -. If both are on, that's a shortcircuit. The transistors don't have the same turn-on/turn-off time so that is something that is possible, but it shouldn't be the case because of the diode/resistor combination at the gates. This should ensure a fast turn off and a slow turn on.when you stated that there might be a concern with T7 being on when any other transistor is on, makes me really want to test with a resistor like you laid out earlier (post #144) but how will there be a voltage spike when nothing else is hooked up (no load) will it spike through T8? And if I understand correctly I will just have a 1k resistor between the drains of T7 and T8 and put the leads of the volt meter on each side of the resistor... I should get 0 volts at all times?
No, not for your application. I would like to know why it's there though.so that oscillation is a big concern huh?
The 555 frequency should be 15Hz, i.e. 15Hz / 6 (60 degree coils) = 2.5 RPS...While probing one of the outputs on the 4017, I pause the scope and counted how many times one output pulsed on 1 second sweep and it was 84 times per second with an RPM of 5040, and that was at 1 meg ohms of resistance.
Is this right? and if so, I will need a way for it to start off slower than that.
Yes.When you say 15Hz is that due to the potiometer/capacitor combonation in the circiut?
No. The capacitor at pin 6 and 2 (which are tied together) in combination with the 1MΩ determine the oscillator frequency.Another way is to change the capacitor at pin #5 to ground on the 555, a higher capacitance (10nF) will increase RPM and lower capacitance (10uF) will slow it down.
Is this correct?
Do you have a manual of the scope?You have to school me a bit more, how do I determine frequency?, I messed around and looked through the options of the scope and it appears that I don't have anything that will tell me Hz.
| Thread starter | Similar threads | Forum | Replies | Date |
Neodymium magnet Vs electro magnet strength. | General Electronics Chat | 11 | |
| B | electro magnet help and advice | Technical Repair | 21 | |
| L | cricut electro magnet | General Electronics Chat | 3 | |
| A | I need reversable DC pulse electro magnet driver | General Electronics Chat | 3 | |
| C | Electro magnet alternating circuit | General Electronics Chat | 15 |
