Bordodynov
- Joined May 20, 2015
- 3,431
hi c999,The workload doesn't really interest me
Thus, both transistors are located at reverse displacements of collector junctions. You ask questions, but you are too lazy to simulate the scheme and look at it yourself. Or are you used to having everything chewed up for you?ericgibbs. The workload doesn't really interest me. The main thing is to stabilize the circuit.
Bordodynov. That is, in this way we force Q2 not to go into saturation, fix the BC transition under reverse voltage?
You're wrong. Read the educational literature so as not to make illiterate assumptions.For example, it seems to me that there is too much blockage in the upper frequencies, there is also a need for positive feedback on the upper frequencies. Will it be possible to align the gain with them?
___
___
___
___
