Dynamic resistance
Сергей999
Joined Jun 9, 2022
63
ericgibbs. The workload doesn't really interest me. The main thing is to stabilize the circuit.
Bordodynov. That is, in this way we force Q2 not to go into saturation, fix the BC transition under reverse voltage?
ericgibbs
Joined Jan 29, 2010
21,622
hi c999,
Has your tutor stated that the output load the amplifier is driving into, is of no interest.
If so, I find that misleading, one purpose of an amplifier is to use the output to drive a load of a given impedance.
E
Bordodynov
Joined May 20, 2015
3,431
Thus, both transistors are located at reverse displacements of collector junctions. You ask questions, but you are too lazy to simulate the scheme and look at it yourself. Or are you used to having everything chewed up for you?
Сергей999
Joined Jun 9, 2022
63
For example, it seems to me that there is too much blockage in the upper frequencies, there is also a need for positive feedback on the upper frequencies. Will it be possible to align the gain with them?
Danko
Joined Nov 22, 2017
2,247
