Dynamic resistance
Bordodynov
Joined May 20, 2015
3,430
How do I view the dynamic resistance Q2 in ltspice?
Hi. Your scheme is very bad. It's also very skewed. The upper transistor is in saturation mode. If you rearrange R1 and R2, you will improve the situation somewhat. Once 45 years ago, I also tried to turn on PNP and NPN transistors on the other side, but nothing worked out for me. The slightest change in the resistors changed the voltage on the collectors very much! My goal of getting half the food was never achieved. It is a bad idea to turn on current sources in series (counter). And the dynamic resistance is easily determined. In low-signal AC mode, you supply a 1 Amp AC power source to the desired node.
See
Bordodynov
Joined May 20, 2015
3,430
Do you distinguish between the gain mode and saturation mode of the transistor? I understand you haven't sorted out my information. I switched the circuit using a strange value of the resistor to gain mode. In reality, it is difficult. The slightest change in magnitude greatly changes the voltage at the collector point.
Сергей999
Joined Jun 9, 2022
63
At 1K, the transistor Q2 is in saturation and the collector potential does not change, so the dynamic resistance of 3,7K?
