Driving motors with atmega
Clowo
Joined Nov 24, 2022
Is this circuit okay to drive dc motors with atmega? While sending to one signal input other one will be grounded from microcontroller. If not okay what additions or substractions are needed to create ideal h-bridge for dc motors to drive with atmega?
DickCappels
Joined Aug 21, 2008
10,661
Are you sure you are going to have enough gate drive with only a 7.5 volt power supply, driving the gates through emitter followers?
Can you tell us what the stall current and running current of the motors will be?
drjohsmith
Joined Dec 13, 2021
1,650
If it's an Arduino , Habe you considered using a h bridge hat for the job.
Has all the bits you need , and in my experience is much cheaper than i could make.
sarahMCML
Joined May 11, 2019
703
How about this.
The two NPN transistors could also be MOSFETs. Just don't exceed the MOSFET gate voltages! If using a low supply voltage, they should probably all be Logic level devices. R3 to R6 are just to prevent any chance of oscillation, and you may get away without.
P.S. I left out the 4 protection diodes across the MOSFETs!
Irving
Joined Jan 30, 2016
5,195
Your original circuit isn't going to work well. The problem is, with pwm1 held at 0 and Q1 on, pwm2 should only turn on M3, but as you turn M3 off- slowly, M2 turns on at the same rate. So you are getting massive shoot-through - current through M2 is going through M3 to ground - see simulation below You need to control M. You need to actively control all 4 devices, or ensure sufficient gate-voltage management to ensure that top and bottom devices on one side are never on together.
Reloadron
Joined Jan 15, 2015
7,948
You can roll your own from any of several online schematics or simply just buy an off the shelf H Bridge motor driver. When rolling your own just be sure your chosen design can handle the motor load to include start current. Also in your code consider if your chosen motor can go from FWD to REV less a delay in your code. A Google of H Bridge modules should bring up plenty of choices. The older L298 is used on many available online but there are newer versions. Most are 5.0 logic compatible suitable for uC boards like Arduino or similar. Most will also take a PWM input.
Ron
Irving
Joined Jan 30, 2016
5,195
Ron
I agree. Unless you have a strong desire to build you own (which WONT be cheaper than ready-made) the DIY v off-the-shelf war has long been won by single chip examples. The venerable bipolar L298 is as cheap as chips but limited, its MOSFET equivalent is only marginally better (L6203), but there are a slew of other options such as DRV8874, DRV8876, LMD18200, LMD18245 etc. As most are SMD parts its much easier to buy off-the-shelf boards in various form factors. A lot depends on the motor you are trying to drive and the demand you put on that motor - not knowing that, its hard to suggest further...
