ronsimpson
- Joined Oct 7, 2019
- 4,914
There needs to be a 100 resistor to limit the current if the switch opens at the peak of the line waveform. (27 to 220 ohms)I think, in any conditions, for example, contact bounce, amplitude of pulse LED current must be not more than 20 mA.
Often there is a 1meg to 4.7meg resistor across C1 to blead down the voltage.
It is typical for a 20mA LED to handle 30mA under some conditions and 100mA for a short time. You could add a 1k resistor to limit the worst-case current.
