AlbertHall
- Joined Jun 4, 2014
- 12,637
Have you ever had it working or did it come to you in its present state?
It still keeps powering on and off after I removed power transistors (Q112, Q113, Q162, Q163, Q212, Q213, Q262, Q263)What do you mean "even without power transistors"?
One possible cause is one (or more) of Q656 to Q659 is shorted.
Yes, without output transistors. The same is when I solder them in. The Q651 keeps the protection turning on. So the voltage on base and emitter climbs to 15V, the collector climbs to 5-6V and when protection is triggered drops down. I do not understand the reason. Transistot looks good. But system works stable without it. Maybe it could be the problem with current sensing resistors?Is this still with all the output transistors removed?
What voltage do you get on the collector of Q651?
Is Q651 the correct type of transistor?
Is Q651 fitted the right way round?
[EDIT] Does Q651 check as a working transistor
