- Joined Jan 23, 2018
- 28,602
For the non-computer automotive alternator mechanical relay system, the field is switched on until the system voltage reached an upper limit, about 14 volts in the cold, perhaps 13,.6 volts in the warm, at which point the field current is switched off until the voltage drops a small amount, when it then switches back on. There is no set frequency, but rather a dancing between limits.
