DC Boost Converter (5v to 12v using LM2577) not powering load
28,527
Inductors very seldom fail, unless they are physically damaged or burned up. With some study it should be possible to be able to estimate the power capacity of a switch supply inductor. But for those supplies with a multiple winding tramsformer the estimating may not come close.
28,527
Should be just as accurate. It might help to combine all the secondaries to one.
I was referencing the estimating based on visual inspection method. Using an electronic measuring system each winding would be measured by itself, since they are connected to separate parts of the circuit.
