Data Acquisition from VCU via CAN Logging for REEV Project – Need Guidance!
TVS
Joined Oct 5, 2024
Hello everyone,
I'm currently working on a Hybrid vehicle project called REEV (Range Extended Electric Vehicle) for a competition organized by SAE India. The VCU in our car is connected to critical components like the battery, motor, generator, and various sensors. I need to acquire data such as sensor readings, battery status, motor and engine RPM, and generator voltage. However, we're not allowed to modify or access the VCU's code, as it’s being programmed by SAE India.
I’ve thought about using CAN logging to capture and decode the data I need since I cannot directly interface with the VCU code.
Here are my key questions:
  1. Is CAN logging a feasible and reliable method for acquiring real-time data from the VCU?
  2. What tools or hardware (e.g., CAN analyzers, OBD2 loggers) would you recommend for logging and decoding CAN messages effectively?
  3. Are there any specific approaches or best practices for identifying the right CAN IDs and decoding them into meaningful parameters?
  4. Is there a more efficient or alternative way to log this data, considering that modifying the VCU software is off-limits?
Any advice, recommendations, or shared experiences would be greatly appreciated!
Thanks in advance for your help!
geekoftheweek
Joined Oct 6, 2013
1,429
Since it is an SAE sponsored competition have you asked if the CAN protocol is available to the contestents? The problem with CAN is even though it is a standard there is no standard as to how the data is used. Other than standard diagnostic messages mandated by the government for emissions the rest is up to the manufacturer. The easiest and best way is to get your hands on the protocol used and go from there.
