Data Centers craze ...
cmartinez
Joined Jan 17, 2007
8,867
I found an article in which a guy named John Valentine, who claims to have extraordinary credentials, argues that the current Data Center craze is being driven not so much by the current advances in AI, but by companies running extremely inefficient software (at least that's what I understood) dating all the way back to the 1980's ... My BS detector is ringing loudly on his claims, but I haven't found a way to verify his credentials, nor if what' he's saying is actually true.
Here's the article I'm referring to. And here's a two-minute video of part of his alleged testimony:
Any thoughts?
Reloadron
Joined Jan 15, 2015
7,961
Data Centers have become a hot topic here in Ohio with the onset of mid-term elections. I have seen them misrepresented in a dozen ways. The big question being do they increase my electricity cost? Personally I have not seen any large increase in my electric bill.
Ron
dl324
Joined Mar 30, 2015
18,477
It sounds like BS to me. AI needs data centers because they need huge amounts of compute resources to drive and develop their engines. Data centers are a way to have a lot of compute power in one place, presumably where infrastructure (power, water, land, etc) prices are more reasonable than residential areas. They sell compute resources to whoever wants them. That would be difficult to do by using the resources of computers belonging to individuals that are not dedicated to applications using compute servers. Additionally, that $4000 computer is likely not configured to run "server" applications effectively or efficiently and availability isn't constant.
For me, it's going to be difficult to determine whether data centers affect consumer electricity prices in any meaningful way because residential customer usage is variable and power utilities raise rates for various reasons.
If new infrastructure needs to be put in place, someone has to pay for it. Is it the data centers exclusively? Or are power utilities charging everyone for the improvements? Data center usage will be pretty much continuous. If residential customers are offsetting cost by prioritizing off-hour usage, data centers also use power during off-hours. It seems to me that the excess supply during "off-hours" would become less available, so prices would increase based on supply vs demand.
The thing I can't understand is why the approving agencies involved aren't requiring water used for cooling data centers to be recycled. I've seen numbers saying some data centers use 300,000 gallons of water per day (100M gallons/year if none of it being recycled). It should be an absolute requirement that data centers use resources like water efficiently.
38,861
They typically use evaporative coolers, which evaporate a significant portion of the water to do the cooling.
dl324
Joined Mar 30, 2015
18,477
That's what I don't understand. They're going to be there for the long haul. Why not do the right thing and use a closed loop system for cooling?
cmartinez
Joined Jan 17, 2007
8,867
People already complain about the noise ... their constant humming day and night ... a closed loop system would probably increase that noise significantly.
schmitt trigger
Joined Jul 12, 2010
2,260
Data centers consume so much energy, for both the computing and the cooling aspects, that at least the ones that I have personally seen, have enormous gensets to support a significant percentage of their power requirements.
In the past those gensets would have been driven by diesel 4 stroke engines, but nowadays they are almost always turbogas engines which are noisy as hell. At night on the usually quiet countryside, one can hear their whine from miles away.
And then there is the cooling. As others have mentioned, the data centers traditionally have used evaporative cooling, but with the drought affecting almost everywhere, they are being designed with closed loop cooling, but the heat from that loop must still be dumped somewhere. Usually a river or lake.
38,861
And many of those centers are nowhere near a river or a lake.
schmitt trigger
Joined Jul 12, 2010
2,260
Exactly, Cruts.
That was the reason for the wasteful evaporative cooling in the first place.
With the backlash, many data centers are now looking to be at the edge of a lake or river.
But many locations don’t have it readily available, so we’ll continue to see additional evaporative towers in the future.
