DAC714P bipolar connecting
Dukel192
Joined Feb 21, 2018
16
I'm getting a bit confused trying to figure out what components I need to connect the DAC714P in Bipolar mode ±10V This is the datasheet: http://www.ti.com/lit/ds/symlink/dac714.pdf On page 11 the wiring diagram is given for ±10V bipolar mode. On the right hand side are the following components given:
Could someone tell me if these should be the suggested D/As CMOS specified on the same page (11). And if this is true, these have 12-bit resolution wouldn't this be a problem while i'm using 16-bit. The DAC714P is 16-bit!
What I think is that these two components are one of the D/As CMOS, for example the DAC7800 : http://www.ti.com/lit/ds/symlink/dac7802.pdf and page 10 shows where to connect Vref A and Vref B and that a lot of other components are to be connected. There should also be a feedback loop towards Rfb A/B should that connection be in front of the C1 on the figure below?
Hope someone can help me with this, I'm making a prototype.
Best regards,
Dukel
Dukel192
Joined Feb 21, 2018
16
Ok, I'm making it to hard for myself. I don't need a Gain and Offset Adjustment.
The datasheet has a Manual Offset and Gain Adjust circuit but this is for ±5V output range. I do need the ±10V.
Can anyone help me with changing the circuit to ±10V
Thank you
ericgibbs
Joined Jan 29, 2010
21,439
hi 192,
Welcome to AAC.
Have been looking thru the datasheets you have posted, I would say for +/-10V 16Bit Bi-polar operation you will need Gain and Offset adjustment.
I must say the d/s is not all that clear.
E
Dukel192
Joined Feb 21, 2018
16
Hi Ericgibbs,
Is there no way to adjust the ±5V circuit to get ±10V, maybe by changing the +10V referece to +20V
Dukel
ericgibbs
Joined Jan 29, 2010
21,439
hi.
Looking at Fig#1 , block diagram, shows the internal Vref at +10V is internally connected to the DA switches.
I would say that trying to force the Vref to +20v will cause problems.
To build the required circuit as shown in image A002 would be my option, use the OPA types specified.
E
EDIT:
The clip you posted are trim pots to set the 0 thru 10V Vref's
Dukel192
Joined Feb 21, 2018
16
hi.
E
EDIT:
Thank you for your response I will indeed take te Op amps specified if I make this circuit, About the trim pots
those are the suggested D/As CMOS right? If I for example take the DAC7800, do I just wire a feedback from VoutA to Rfb A. In front of the capacitor?
could you also take a quick look at this datasheet http://www.ti.com/lit/ds/symlink/dac7731.pdf wouldn't this be a lot easier, there is almost no need for extra electronics, only thing is that it is not a DIP package so harder to solder on my own for a prototype.
Dukel
