Fast Bipolar -10v+10v analog signal isolator
Hadaak
Joined Jul 17, 2015
52
Hi Guys,
I have a mesa 7i77 card i'm using with linuxcnc to run a plasma cutter table. I burnt two cards so far. card is like 300$ a piece.
I am now trying to isolate it from all the other electrical stuff around. I know I have to go over all the wiring and all that but I thought why not add additional security and isolate the analog outputs and inputs of the card. I asked the major AI guys and they suggested I make my own board. I have never designed a board but I am good with a soldering iron. I did emphasize that I want a through hole diy board and even asked AI to put socket for components to make replacing them easier. I also looked on the net for solution but they are almost as expensive as the mesa board itself. I did find an aliexpress din rail isolator but the response time is 10ms. I bought one to test though. The modded plasma table I retrofitted to use linuxcnc dates back to 1995. not sure the drives will tolerate a 10ms lag.
back to my project. here is what the AI guys advised:
2 channels isolatation board:
Category,Qty,Reference,Value / Part Number,Package,Description,Unit Cost Est.,Line Cost Est.
Power,1,U3,TPS7A3901DGNR,VSSOP-24,Dual ±15V Voltage Regulator,4.20,4.20
Power,2,L1, L2,10µH,7x7mm,Power Inductor,0.50,1.00
Power,4,C_IN,22µF 25V X7R,1210,Regulator Input Cap,0.15,0.60
Power,4,C_OUT,10µF 25V X7R,1210,Regulator Output Cap,0.12,0.48
Isolation ICs,2,U1, U2,HCPL-7840-000E,SOIC-8,Isolation Amplifier,3.50,7.00
Gain Setting,8,R_GAIN,10.0kΩ 1%,0805,Gain Setting Resistor,0.02,0.16
Filtering,4,C_FILT,100pF NPO,0805,Input Filter Capacitor,0.03,0.12
Decoupling,14,C_DEC,100nF X7R,0603,Power Decoupling Cap,0.01,0.14
Bulk Decoupling,2,C_BULK,1µF X7R,0603,Bulk Decoupling Cap,0.02,0.04
Protection,2,TVS_IN,SMBJ12CA,SMB,Bidirectional TVS (±12V),0.25,0.50
Protection,1,F1,1812L150/60DR,1812,Resettable PTC Fuse (1.5A),0.50,0.50
Protection,1,TVS_PWR,SMBJ28CA,SMB,Unidirectional TVS (28V),0.25,0.25
Indicator,1,LED1,Green LED,0805,Power Indicator LED,0.10,0.10
Indicator,1,R_LED,2.2kΩ,0805,LED Current Limit Resistor,0.02,0.02
Connectors,3,CONN,3-pin Screw Terminal,5.08mm,Signal/Power Connector,1.10,3.30
PCB,1,-,PCB 2-Layer,80x100mm,Custom Circuit Board,5.00,5.00
And the board design instructions:
LINUXCNC PLASMA CUTTER - 2-CHANNEL ANALOG ISOLATOR
BOARD CONNECTORS:
PWR_IN (2-pin): PIN1 = +24V_IN, PIN2 = PGND
CH1_IN (3-pin): PIN1 = CH1_IN+, PIN2 = CH1_IN-, PIN3 = GND_CTRL
CH2_IN (3-pin): PIN1 = CH2_IN+, PIN2 = CH2_IN-, PIN3 = GND_CTRL
CH1_OUT (3-pin): PIN1 = CH1_OUT+, PIN2 = CH1_OUT-, PIN3 = GND_ISO
CH2_OUT (3-pin): PIN1 = CH2_OUT+, PIN2 = CH2_OUT-, PIN3 = GND_ISO
PWR_OUT (2-pin): PIN1 = +15V_ISO, PIN2 = -15V_ISO
POWER SUPPLY WIRING:
PWR_IN:
PIN1 --> F1(FUSE) --> +24V_F
+24V_F --> TVS_PWR:ANODE
TVS_PWR:CATHODE --> PGND
+24V_F --> L1 --> U5:TPS7A3901(PIN1,VIN)
PGND --> U5(PIN3,GND)
U5(PIN8,VOUT1) --> +15V
U5(PIN18,VOUT2) --> -15V
+15V --> U6:LM7805(IN)
U6(OUT) --> +5V
U6(GND) --> GND_CTRL
+15V_ISO --> U7:LM7805(IN)
U7(OUT) --> +5V_ISO
U7(GND) --> GND_ISO
CHANNEL 1 (U1 - HCPL-7840) WIRING:
[CONTROL SIDE]
CH1_IN:
PIN1 --> R1(10k) --> U1(PIN3,IN+)
CH1_IN:
PIN2 --> R2(10k) --> U1(PIN2,IN-)
U1(PIN2,IN-) --> R3(10k) --> GND_CTRL
U1(PIN3,IN+) --> C1(100pF) --> GND_CTRL
CH1_IN:
PIN1 --> D1:TVS(ANODE)
CH1_IN:
PIN2 --> D1:TVS(CATHODE)
+15V --> U1(PIN8,VCC1)
+5V --> U1(PIN1,VDD1)
U1(PIN4,GND1) --> GND_CTRL
+15V --> C5(100nF) --> GND_CTRL [at U1 Pin8]
+5V --> C6(100nF) --> GND_CTRL [at U1 Pin1]
[MACHINE SIDE]
U1(PIN6,OUT+) --> R4(10k) --> CH1_OUT: PIN1
U1(PIN5,OUT-) --> R5(10k) --> CH1_OUT: PIN2
U1(PIN5,OUT-) --> R6(10k) --> GND_ISO
+15V_ISO --> U1(PIN7,VCC2)
+5V_ISO --> U1(PIN5,VDD2)
U1(PIN5,GND2) --> GND_ISO
+15V_ISO --> C7(100nF) --> GND_ISO [at U1 Pin7]
+5V_ISO --> C8(100nF) --> GND_ISO [at U1 Pin5]
+15V_ISO --> C19(1uF) --> GND_ISO
CHANNEL 2 (U2 - HCPL-7840) WIRING:
[Follow CHANNEL 1 pattern with these substitutions]
U1 -> U2
CH1_IN -> CH2_IN
CH1_OUT -> CH2_OUT
R1-R6 -> R7-R12
C1 -> C2
C5-C8 -> C9-C10
C19 -> C20
D1 -> D2
ADDITIONAL DECOUPLING CAPACITORS:
+15V --> C11(100nF) --> GND_CTRL
-15V --> C12(100nF) --> GND_CTRL
+15V_ISO --> C13(100nF) --> GND_ISO
-15V_ISO --> C14(100nF) --> GND_ISO
POWER INDICATOR:
+15V --> R9(2.2k) --> LED1:ANODE
LED1:CATHODE --> PGND
CRITICAL LAYOUT RULES:
1. GND_CTRL and GND_ISO must NEVER connect electrically
2. Maintain ≥8mm gap between GND_CTRL and GND_ISO copper
3. Place 100nF capacitors within 3mm of IC power pins
4. Route IN+/IN- and OUT+/OUT- as parallel trace pairs
5. Keep input and output sections physically separated
VERIFICATION CHECKLIST:
[ ] All HCPL-7840 have correct power: VCC=±15V, VDD=+5V
[ ] Input bias resistors (R3,R6,R9,R12) connect to correct ground
[ ] TVS diodes oriented correctly (cathode band to negative)
[ ] No shorts between GND_CTRL and GND_ISO
[ ] Isolation barrier clearly defined in PCB layout
[ ] All connectors labeled correctly
NOTES:
- GND_CTRL connects to Mesa card ground
- GND_ISO connects to servo drive grounds
- Board provides two fully isolated ±10V analog channels
- Use shielded cable for analog signal connections
So what am I looking for? I'd like to have your opinion whether it's a good idea to go this route, learn some stuff and build this board and be able to repair it when needed, If I order it online I will have a minimum of 5 boards. This gives me 4 spare boards in case of future failures. Or forget about it and go the expensive option? I am not in a hurry and I'm not losing any money going the DIY option by the way. The setup is already working as is but I want to add protection.
I am going to play with a Claude Kicad MCP to see what I can get out of this.
38,855
±10V analog isolators are not common:
Here (Figure 12) is a reference on how to build one using two op amps and two linear opto isolators.
Of course isolation requires no common ground connection, and two separate, ±12-15V isolated power supplies for the input and the output. Can you do that in your setup?
Does that sound like something you would want to do?
If so, we can help with the design.
Hadaak
Joined Jul 17, 2015
52
Thanks for the quick reply.
Yes. What I want to achieve is isolate the analog output and input pins from any external electrical component. I will look into the link you posted and get back; Thanks again.
ci139
Joined Jul 11, 2016
2,034
what you should consider is ?? Is there extra lattency (delay) introduced by the added isolation unit ?? does it matter
if your control chain is not like
send relative/absoluye move/shift coordinates state of cutter to equipment ? wait complete/ready for next command to be sent
e.g.
if your "control board" is somehow dynamically a part in the cutter position adjustment loop - several problems may arise
the probability of the latter option is suggested by "ANALOG isolator" !!!???
panic mode
Joined Oct 10, 2011
5,295
signal isolators and conditioners are very common. any decent electrical supplier will have some, and if you are in the urban area, there will be 20+ of suppliers within couple of miles from you. also online electronics retailes have dedicated section for this, here is DigiKey.
and here are several that will do +/-10V to +/-1-V and the prices and in Canadian $. some of products are universal and allow you to choose independently input and output type, range and scaling.
panic mode
Joined Oct 10, 2011
5,295
if considering DIY, i would rather make something that has several channels and use ADC/DACs that are isolated or, use common ones (without isolation) then add your own isolation on a digital bus.
for example:
MCU (your choice), say RP2040 or whatever.
use bus of your choice (such as I2C).
optionally add multiplexer so that same bus addresses are not an issue (TCA9548 or whatever)
on "side A" side add ADC or DAC or both using chosen kind of bus, for example ADS1115 for analog inputs, MCP4728 for analog outputs
on "side B" side add ADC or DAC or both using chosen kind of bus, for example ADS1115 for analog inputs, MCP4728 for analog outputs.
add I2C isolator like ISO1540DR or whatever between MCU, side A and side B.
use ready made DCDC isolated converters that give you +/-12V or +/-15V. you need one for each side that has DACs.
use OpAmps like OPA2186 to scale DAC signals to +/-10V.
add protection and also anything else you think could come in handy.
38,855
For grins, I generated a modified Figure 17 circuit from my posted reference which uses just one opto.
Below is the LTspice sim:
The bottom op amps provide a small, stable current to bias the isolator at the center of its range for a plus and minus input and output.
It has a -3dB rolloff of about 15kHz.
It's not necessarily optimized for your requirements.
Hadaak
Joined Jul 17, 2015
52
e.g.
Here is the analysis of my setup requirements:
Here is a summary of what your system needs versus what the isolator options provide:
ParameterYour System's RequirementHCPL-7840 (Simple)IL300 (Complex)Verdict
Required Bandwidth> 500 Hz (5-10x servo rate)100 kHz200 kHzBoth exceed by 200-400x ✅
Max Allowable Latency< 100 µs (10% of servo period)~10 µs< 10 µs (circuit dependent)Both meet easily ✅
Required Slew Rate~0.5 V/µs (for 10V step in <20µs)~8 V/µsCircuit DependentHCPL-7840 meets ✅
Critical NeedStability, noise immunity, simplicityGood CMRR, integratedExcellent linearity, discreteSimplicity wins
Hadaak
Joined Jul 17, 2015
52
These devices are more expensive than the board I'm trying to protect :)
The board is a mesa 7i77 by the way.
Hadaak
Joined Jul 17, 2015
52
looks nice even if I don't really read schematics :)
Can this be made in a finished project to be ordered online?
Does it need any tuning before wiring it (once it is manufactured)?
38,855
The HCPL-7840 does require an output differential to single-ended configured op amp or instrumentation amp to get the ±10V output you want, but that should still make a reasonably simple and low-cost circuit.
Likely better than using the IL300.
AnalogKid
Joined Aug 1, 2013
12,281
Burr-Brown (now a part of Texas Instruments) and Analog Devices both are big in the signal isolation field, with analog and digital signal isolators, opamps, ADCs, etc.
ak
ronsimpson
Joined Oct 7, 2019
4,829
There are many different types of analog isolators like this ACPL-C87xx.
I have many of these parts on the shelf. And a number of competitors parts from a project two years ago.
I found them to be better than the TL300. I know I should have a tube of parts from TI also.
I think some have an input voltage of 0.2V or 2V or? I can't find it now, but I think there is one for +/- 2V.
I made a scope probe out of an isolator. 1000V isolation, 100khz bandwidth. I had a variable gain amp on the front end. I needed to measure signals with only some pF back to the scope.
schmitt trigger
Joined Jul 12, 2010
2,252
Ron; I am curious.
What did you use to power the isolated VDD1?
Batteries? or you used one of those isolated board-mounted DC/DC converters?
ronsimpson
Joined Oct 7, 2019
4,829
There is an entire class of small DC to DC with isolation power supplies. This one is 5Vin 5Vout 1W. I needed 1000s of volts of isolation so I used larger ones where there is more separation between input and output. Look at some data sheets. Most have a part number like NME for which model, 1 for watts, 05 for input and 05 for output.
Outputs are often 3.3, 5, 6, 12, 24 and inputs are often 5, 12, 24. So I was using 12405 or 22405.
Look for RFM-0505s
NMV1s0505
RO-0515S
panic mode
Joined Oct 10, 2011
5,295
there is literally tons of them, most are using standard pinout which makes them interchangeable.
couple notes:
you will want one with dual output either +/-12V or +/-15V since signal output is supposed to be +/-10V. also you may want to dig a bit more and pick variant that has higher switching frequency. i usually aim for 500kHz or higher. this is easier to filter. also pay attention to maximum capacitive load. you do not want your filter to make the regulator fail to run. since your analog is voltage type, current draw is tiny (easier to filter). or just use +/-15V so your supply filters can have higher voltage drop.
about cost of industrial signal conditioners - i hear you, but it was just an example that those things are not unicorns. plus, i have developed surprisingly high tolerance for what other people pay...:D
but i did offer another DIY path using digital conversion and multiple channels. that brings per channel cost down and ... it is digital, 3-way isolated etc. with PCBA from JLC or example it would cost some $100... for 5 boards and extra channels. just saying.
schmitt trigger
Joined Jul 12, 2010
2,252
Thanks Ron; I have used those too in several projects.
In one of them though, at low loads the switching went into a skip-cycle mode and the ripple voltage increased significantly.
A simple led indicator load was enough to fix the issue.
Hadaak
Joined Jul 17, 2015
52
So how do I go about my DIY route which will be an interesting learning route? Something I can either solder myself or order online. I'd start with a two channel board to order online so that I can get 5 boards for a total of 10 channels. Something that does not require tuning once created.
