M-Audio Fast Track Pro repair
gdurrens
Joined Oct 16, 2025
We were hit by thunder few month ago and many devices go fried. I repaired some of them.
Our sound card M-audio Fast track Pro is one of the destroyed item.
When opened I noticed these two burnt resistor.
Any idea which value they have ?
I found an image of that pcb there and it seems these resistors are "0" acting I guess as fuses, could it be ?
What do you think ?
Thank you for your replies
meth
Joined May 21, 2016
316
0 is not a fuse, it is a jumper (short circuit). Luckily in your case it acted like a fuse.
Sometimes because of the layout the designer decided to use jumpers, but more often big manufacturers use the same PCB for a family of products.. another soundcard of the same family might have a resistor there.
gdurrens
Joined Oct 16, 2025
thank you meth for your reply and your explanations,
I have some 0 ohm smd resistors around. I'll replace them and let you know.
gdurrens
Joined Oct 16, 2025
I replaced the jumpers. I checked continuity, ok. But no luck.
After further investigation I noticed that chip exploded
Looks like a texas instrument 5(7?)21..
It's in the power supply managment area
what chip could that be ?
meth
Joined May 21, 2016
316
Maybe it is 211 op amp? But I cant be sure, you will have to figure out from the layout, if the pins (VCC, GND, input, output) make sense according to the 211 pinout.
