Could not understand why noise cancellation must be at (fs-fc) for -60dB
TarikElec
Joined Oct 17, 2019
154
I have the overview of signal with cut-off frequency fc that I want to sample using an ADC with sampling frequency of fs, I have seen that some of my colleagues wanted to dumb any noise at -60dB at frequency fs-fc as you see it in the picture.
for my understanding of nyquist theorem, I need to damp any signal over fs/2 for how much -x dB I want. here I could not understand why it is at (fs-fc)
38,952
Aliasing of any signal or noise components above fs/2 occurs.
I believe fc is not the cutoff (-3dB) point of the anti-alias filter, it's the Nyquist cutoff or the same as fs/2.
So you want any signal/noise above fs/2 (which is also the same as fs-fc) to be below the noise floor of the ADC.
The -3dB filter cutoff frequency will thus be below fc by a factor determined by the filter rolloff characteristics and the amount of attenuation you need at fc.
Papabravo
Joined Feb 24, 2006
22,116
In a sampled data system you want to attenuate frequencies above fs/2 and fs, to prevent them from showing up in the sampled data as a mirror image. -60dB puts an explicit specification on the amount of attenuation in the transition band and the beginning of the stop band.
TarikElec
Joined Oct 17, 2019
154
Thank you for your reply. I understand about that we must attenuate frequencies above fs/2 and we want for example -60dB attenuation, but why specify exactly (fs-fc)? I could not understand that
TarikElec
Joined Oct 17, 2019
154
the fc represent the cut-off frequency and I could not imagine why fs-fc and not just fs/2 as I learned it and understood it
