Yes. I don't think there is any way to get true DC response from a BBD. See the attached schematic, copied from the MN3207 datasheet. Notice that the input to the chip is AC coupled to an adjustable DC level.Thanks for the informative post. So what you mean is, that the entire waveform must be shifted vertically so that all of it appears only on the +ve side? and then that should be fed into the BBD?
You can learn a lot from datasheets.
That won't work.How about i try to split the input signal into positive and negative part and then feed them separately? But how would that be implemented, like using the inverter?
The bars and spikes can be removed with a sample and hold. Have you tried one yet? You would still need a filter, but it would not have to remove so much clock crap.Basically, right now i was thinking maybe my circuit is not giving the output as desired, as the input signal fluctuates b/w +ve and -ve.
If you see, you can clearly see some delay, however there are too many 'bars' or spikes in the output.
