Changing LED transformer board
Tonyr1084
Joined Sep 24, 2015
9,744
those things suck the clear wire is easy to hook up backward
Am assuming those wires have not been disturbed. However, that's a good question. If someone did rewire it - there's the chance it COULD be wired backwards. I'm wondering if there's a way for the TS to make sure power from the PS is on the correct side of the controller/driver board.
Tgi8
Joined Oct 3, 2025
21
I ran a voltage tester on the two outputs as requested earlier and got current.
if the resolder job is the proposed way forward, how simple is that as a job for a total newbie to this, or am I best getting someone who may work with computer chipsets to do it for me ?
Tgi8
Joined Oct 3, 2025
21
Forgive my naivety, could someone please explain further about wiring backwards?
Tonyr1084
Joined Sep 24, 2015
9,744
LED's are not only current based devices they are also polarized. They have a positive side and a negative side. Wire them backwards and they won't light. Force too much current through them backwards and they'll blow out.
Who soldered those wires on the controller?
Tonyr1084
Joined Sep 24, 2015
9,744
What I would do on my work bench if I had this job to do is mark which wires are connected where, then carefully remove the output wires first. Then power the unit and test for proper voltage on the output side. If it seems to be working properly I'd get another LED and hook it up to determine which wire is positive even though it claims on the board which is V+. Knowing the controller is working I'd then touch the wires first the way they came off. I would expect the lights to work. But if not I'd then try swapping the two wires. If the lights light up then the whole problem would be that it was wired backwards. If it still doesn't light up I'd look for the first common point where all the LED's connect back to. With that tangle of spaghetti that might not be so easy to do. But as sghioto said, it could be an open line somewhere. The next test would be to find it.
Years ago the way things were wired if one bulb went out the whole string would go out. You'd have to find the dead spot and replace the dead bulb. Today they make them so that if one bulb goes out the rest of the string continues to light up. So I don't think you have a bad LED in the string(s) but rather, if it is a simple open circuit then it would probably be a spliced junction. However, you DID mention that water got into the controller and that's when problems began.
On that premises, if water got in it's understandable that it wouldn't work. But once dry it should work. The way those solder joints look - I'm heavily leaning to saying either the solder joints are bad or as sghioto suggested, it could be wired wrong IF (big IF there) but IF someone rewired it there's a chance it was wired incorrectly. Unfortunately this is not on my bench so I can't test it for you. It's up to you to figure it out. This is about all I can give you.
Tonyr1084
Joined Sep 24, 2015
9,744
I was just re-reading post #13 when suddenly I remembered working on a 24VAC sprinkler system. Even though there was power at the sprinkler valve, the valve wasn't opening. So I bought a new valve only to have the exact same thing continuing to be the problem. I began to fear that it was a plumbing issue. But I decided to swap control lines. Suddenly the valve that wasn't opening was now functional and the donor valve wouldn't. So I traced back the wiring to several splices in the sprinkler control lines that were buried under ground and protected with just black tape. Moisture had gotten in and contaminated the connections to where they would pass voltage but not sufficient current to open the valve.
What does that have to do with your issue? It's that corrosion in the connections. You could be reading voltage but it can be so bad that enough current can't get through and light the lights.
DO YOU HAVE soldering tools and solder? If so then you really need to clean up those connections. I strongly suspect the issue may be fixed right there. But even that's not a guarantee. It can be incorrectly wired just as sghioto said.
Tonyr1084
Joined Sep 24, 2015
9,744
Bought a LED lighting set up last year, but storms bent some of the wiring and exposed circuit board to water.
"Bent some of the wiring" means a chance a wire is broken somewhere but not separated. I've seen damaged wires broken inside the insulation so you can't SEE the damage but it's there.
Had professional strip wiring and wiring is now all safe - but can’t get the lights working
"Had professional strip wiring" tells me someone messed with the wiring. Who was the professional who stripped one or more wires? Can you be sure they put them back correctly?
And what is this black wire and barrel connector plugged into?
[edit] on top of all that - it looks like the wires may be aluminum wires. Aluminum wires can be brittle and easily broken.
I really don't like the product you bought. Made in China means it's likely to be made of Chinesium. Garbage in other words. You may be chasing a failure you can never catch up to.
Tgi8
Joined Oct 3, 2025
21
Hi Tony / all
I’ve just read the latest posts, this is really helpful to help me understand the troubleshooting as a newbie in this area.
I don’t currently have any solder or equipment but can look into..,
forgive the total naivety, but how could I check to see if there is an open part of the circuit at all as the entire device is insulated.
I attach some images that show what happened last year, before moisture got in the control panel - and a local electrical crimped and resolved for me.
however, the functionality then turned highly erratic for 24 hours before shutting off entirely.
be80be
Joined Jul 5, 2008
2,395
You said you had some one re wire this the wires on those leds have plugs that you can only plug in positive positive negative the negative but were you soldered them? They could’ve reversed them
sghioto
Joined Dec 31, 2017
8,634
Does it matter the polarity?
Doesn't the RGB driver reverse the current direction for different colors?
Still suspect a broken connection.
MisterBill2
Joined Jan 23, 2018
27,552
OK, a whole lot of comments. FIRST, though, those lights change colors??? With only two wires?? THAT means that there is a lot more than just DC on those wires.
LOOK VERY CLOSELY, and you will see that one side of the wire has a tiny rib molded on, the other side does not. OR it might be a tiny stripe on only one side, I have seen both methods recently. Which is positive is unknown. BUT if it is wrong, it will not work right.
The secret of re-soldering connections correctly is to only take one at a time apart!! BUT while the four solder connections were not pretty at all, they looked solid enough to me. A poor connection will come apart. CERTAINLY there is no transformer in that controller, probably not in the power supply either. It would be a switcher because they are cheaper to do currently.
Tgi8
Joined Oct 3, 2025
21
What is that black plug and cable connected to in post #31?
Hi Tony, forgive me / that is unrelated and from a different product that shouldn’t have been in shot.
Although a total newbie, I am willing to give a resolder a go - and can purchase some very affordable kits to try this before throwing too much at an issue that may be unresolvable.
If I understand the comments correctly, are the leading suggestions that it may be a faulty connection on the driver / or an open circuit (if the latter how can I check and test for this)?
Tgi8
Joined Oct 3, 2025
21
Yes they do change colours, meant to cycle through 8/10 colours and each LED can display multiple colours
MisterBill2
Joined Jan 23, 2018
27,552
Back in post #18 we see a picture of a 24 volt DC power supply. What I suspect now is that a splice has been made with the connections reversed. THAT is what I would first suspect from somebody who was unable or unwilling to observe and follow the polarity markings. Certainly the broken end that we are shown indicates that the wire broke under tension. So there may also be a conductor pulled out of a connector along that same section. A close inspection, with adequate light and a magnifier is the next step.
