I want to understand about connection diagram of tap changing transformer.
Ian0
Joined Aug 7, 2020
13,117
27,358
Transformer windings are not "end tapped", they are connected to at the ends.
A transformer winding is a linear system, meaning that voltage is induced along every segment of a secondary winding. This means that a connection at any point will have some voltage.
The TS needs to study transformers and related magnetics some more!
MaxHeadRoom
Joined Jul 18, 2013
30,605
A transformer winding that is centre tapped provide a ± phase shift of 90° on each end WRT the centre tap,
Often used for full wave rectification using 2 diodes,
This is also the method of used to supply domestic power in NA.;)
Correction: should read 180° WRT the CT
Ian0
Joined Aug 7, 2020
13,117
Transformer windings are not "end tapped", they are connected at the ends.
The TS's reference refers to transformers that are tapped 0-220-230-240 as being "end-tapped" - no, I've not heard the term before, they were just "tapped".
Ian0
Joined Aug 7, 2020
13,117
90° phase shift from a transformer! You'd need Scott-T to do that.
