Capacitors! Most useful values? pF/puffs are good for what?
Hamlet
Joined Jun 10, 2015
560
I was looking over my collection, making an order to fill the depleted values (100nF, 10nF, 0.47uf etc.)
What values do you guys and gals use the most?
Why do I have 43 different values of ceramic disc below 1nF? I rarely seem to use those puffs, what & where are those values used?
35,198
Same question can be said for resistors.
Where and how often does one use a 1Ω or 22MΩ resistor?
The answer is - it depends on your field of study and application.
For example, you will need 6pF to 22pF capacitors and 22MΩ resistors if you were building a crystal oscillator circuit.
MaxHeadRoom
Joined Jul 18, 2013
30,818
As per MrChips, it all depends on the application, as a very general rule, the higher the frequency used by the application, smaller values are seen.
RF decoupling etc.
Max.
38,848
Look at the schematics for the typical circuits you are interested in and you will see what values of resistors and capacitors are commonly used.
35,198
Let us look at some broad applications. What type of circuits are you most likely to be building?
  • Audio amplifiers
  • Audio tone controls
  • FX stomp boxes
  • Linear power supplies
  • Switch mode power supplies
  • 4000 or 7400 series digital circuits
  • Microcontrollers
  • Arduino or raspberryPi boards
  • RF or HAM radio circuits
wayneh
Joined Sep 9, 2010
18,169
Anytime I buy a capacitor, I usually by several. They're cheap and I might want to duplicate whatever it is I'm building. The only capacitor value I've bought in bulk to have a pile on hand is the 0.1µF ceramic caps for decoupling. I go through those like candy.
35,198
4000 and 7400 series digital circuits
You will need lots of 0.1μF disc capacitors
Some 10-100μF electrolytics
Occasionally, some 100pF to 1μF for timing circuits
1-10μF ceramics
100-4700μF bulk electrolytics.
SMPS
Same as above, according to datasheet recommendations
35,198
There are many different types of materials and construction techniques used in the process of manufacturing capacitors.
There is no one better than the other. They all have different properties and characteristics such as stability, reliability, temperature dependency, ESR, leakage, aging, voltage breakdown, and of course cost.
@bertus has already posted in post #7 some helpful documents on choosing capacitors.
Hamlet
Joined Jun 10, 2015
560
Reading, reading, readin...
QUESTION:
Capacitor voltage rating... Apart from larger size,
is there any disadvantage to using a 250v electrolytic
in a 12v circuit?
Hamlet
Joined Jun 10, 2015
560
Never-mind, found my answer in the PDF. For those who want to know,
electrolytics are closer to their value at intended voltages. (I don't see
how that's possible.) Also something about the oxide being maintained
at lower voltages than rated is problematic somehow.
Hamlet
Joined Jun 10, 2015
560
I just tested a dozen 10uf electrolytics from 16v all the way to 250v, and could NOT
discern any meaningful difference in capacity. Admittedly, my LCR meter is a cheap
one.
