Can L298N run linear actuator, Sumret SRA6000?
CK12780
Joined Jun 11, 2023
6
Good day to you all, i am new in arduino and electrical. I am trying to run the linear actuator model Sumret SRA6000 with motor driver L298N. Will it works? If not work, what motor driver can i use for synchronize both linear actuator and is there any source for reference?
Thank you.
Specification SRA6000
stroke:250mm
Load capacity:6000N
No-Load capacity:5mm/s
Input voltage: dc12V
Below is the code that i use in Arduino.ide
Mod: added Code quotes.
C-like:
#include <ActuatorsAndSensors.h>
#define IN1 2
#define IN2 3
#define ENA 4
//Instantiate the Linear Actuator
LinearActuator LinAct(IN1, IN2, ENA);
void setup() {
  //Allows the actuator to recieve power
  LinAct.turnOn();
void loop() {
  int pwm = 255;
  //Sends the actuator up at specified pwm (default value of 255 if not passed)
  LinAct.goUp(pwm);
  delay(5000);
  //Stops linear actuator motion until a goUp() or goDown() but doesn't turn it off
  LinAct.pause();
  delay(5000);
  //Sends the actuator down at specified pwm (default value of 255 if not passed)
  LinAct.goDown(pwm);
  delay(5000);
  //Turns the linear actuator off, goUp() and goDown() will not work until turnOn() is called
  LinAct.turnOff();
sarahMCML
Joined May 11, 2019
707
Thank you.
stroke:250mm
Load capacity:6000N
C-like:
#define IN1 2
#define IN2 3
#define ENA 4
void setup() {
  LinAct.turnOn();
void loop() {
  int pwm = 255;
  LinAct.goUp(pwm);
  delay(5000);
  LinAct.pause();
  delay(5000);
  LinAct.goDown(pwm);
  delay(5000);
  LinAct.turnOff();
From what I see, looking at the Aliexpress website, it uses a 60W motor, so no, you can't use the L298N driver. You need one that can supply at least 5 Amps minimum.
CK12780
Joined Jun 11, 2023
6
From what I could see looking at the Aliexpress website they use a 60W motor, so no, the L298N is out of the
Ok thanks, so can I use BTS7960 motor driver for this?
