Ghar,
Try reducing L1 to the 100uH-200uH range. You're operating at 50kHz, so 100uH should be just about right.
Increase C1 to roughly 200uH to reduce your ripple current.
I'm not certain why you included D3; it should not be necessary.
You should limit the Vgs of your MOSFET so that it doesn't exceed about -10v. Most MOSFETs have a Vgs limit of +/-20v, and you are almost at the -20v limit. The easy way to fix that would be to put a 10v Zener in parallel with R4, and decrease R6 to ~500-1k Ohms to get 20mA to 10mA through the Zener to ensure proper regulation.
