Broken LCD from Mitsubishi MSZ-SF23VE3 remote control
Gi.an.
Joined Dec 14, 2022
7
My beloved fellows,
I broke the LCD from my Mitsubishi MSZ-SF23VE3 air conditioner remote control (TYPE: SG15D 1538).
Below is a working one for reference:
And below is the broken one apart showing, the PCB and the broken LCD:
The LCD isn't soldered and just sits on the PCD, making tight contact screwed on it.
It has a serial number MD-0433-003 on the back and below 17-10-06 probably as the creation date:
Now you can tell me that I am a little bit weird, but I can only find this "compatible" RC below, but it isn't the same as the original...
Also I am not sure if it has the same modes as mine...
So, I would really appreciate your help if I could find a replacement LCD (if its possible), or the same remote control.
Thanks in advance for your help and suggestions! :)
Gi.an.
Joined Dec 14, 2022
7
Also from a search I did, this broken LCD is called COG (Chip-On-Glass) LCD with Zebra or Elastomeric Connectors on top and bottom.
28,600
An actual "chip-on-glass" LCD is a custom device with specific internal logic inside the chip. The only option is to replace the broken part.
If your air conditioner has a local control option then you will need to use that. Ifthe remote control that looks different is able to control, you are fortunate.
Gi.an.
Joined Dec 14, 2022
7
I'm afraid you are right...
So, my only chance is if I could find a used original, as long as I don't want to use a replacement...
Gi.an.
Joined Dec 14, 2022
7
I will order a replacement and see if I can fit the LCD screen to the original control.
I will inform you in a few weeks with the results...
