Bilge pump circuit for model sailboat
Ken_NJ
Joined Feb 22, 2021
137
Here is what happens with LED addtion wired up.
Probes out of water. Pump is off, OK. LED2 comes on dimly.
Put lower probe in. Pump does not go on, OK. LED2 goes brighter.
Lower and upper probe in. Pump is on. LED1, 2 & 3 are on. Looks good.
Remove upper probe, lower still in water. LED1, 2 & 3 are all still on.
Both probes out of water, pump stops. LED1 & 3 off, LED2 is still on.
Power cycle.
Probes out of water. Pump is off. LED2 goes on.
Press the momentary switch SW2. Pump goes on. LED1 & 3 go on. When the momentary switch is off LED3 goes dim slowly like the discharge of a cap.
Power cycle.
When I used the trabmitter/receiver/servo, SW1. The same happens as the momentary switch.
Ken_NJ
Joined Feb 22, 2021
137
D5 checks out OK. Added those two resistors.
Now....
Apply power. Probes out of water. LED2 comes on. Put lower probe in and out of water, LED2 always on. Checked this multiple times.
Both probes in water. Pump is on. All three LEDS on but LED 1 and 2 are dimmer than usual.
Remove upper probe. Pump stays on, OK. Sometimes LED3 goes off.
Remove lower probe. Pump goes off. LED2 stays on.
Push SW2.
Pump goes on, OK. LED3 goes on and off as SW is pushed. Same applies to transmitter/servo.
sghioto
Joined Dec 31, 2017
8,750
Something isn't connected correctly is my assessment.
What transistor are you using for Q2 and Q3?
LED3 should not come ON when SW1 or SW2 is pressed because of diode D5.
Ken_NJ
Joined Feb 22, 2021
137
I'm working on getting it all in Kicad for myself. Give me some time.
It's what you posted in post #101 with the 100k resistors.
sghioto
Joined Dec 31, 2017
8,750
No, should look like this:
If LED2 is always ON then R3 must be connected to terminal 1 of the low level electrode. It should be connected to terminal 2.
I need to see a photo of the actual circuit to try and troubleshoot or you can help with a multimeter.
Ken_NJ
Joined Feb 22, 2021
137
Yes
Yea the wires got out of hand. Ran out of short wires. I could take it back without the LED's and start over adding them.
Ken_NJ
Joined Feb 22, 2021
137
With probes out of water. 0.56v (LED was off).
Put probe in water went to 4v, then it slowly decreased. And LED was still on.
Ken_NJ
Joined Feb 22, 2021
137
When the probe was put in the water, it started at 4.2v. Then it slowly decreased, after about 1 min it was 3.1v and just about stopped decreasing.
