B Class Self-Commutation Thyristor
salhi
Joined Nov 29, 2023
86
Hello Community, i want to understand the internals of this circuit which are illustrated in this graph (ignore the red curve), i would like to know how the turn off of the thyristor happens
salhi
Joined Nov 29, 2023
86
This schematic is not complete. There has to be a second part of the inductor that is missing.
can you elaborate more because from my professor notes i doubt its incomplet here is another version, can you tell me where the (E+U0)/R come from
Ramussons
Joined May 3, 2013
1,572
From https://circuitdigest.com/tutorial/thyristor-commutation-technique
Resonant-Pulse Commutation
Class B commutation is also called as Resonant-Pulse Commutation. There is only a small change between Class B and Class A circuit. In class B LC resonant circuit is connected in parallel while in Class A it’s in series.
Class B Thyristor Commutation Technique
Now, as we apply the input voltage, the capacitor starts charging upto the input voltage (Vs) and Thyristor remains reversed biased until the gate pulse is applied. When we apply the gate pulse, the Thyristor turns ON and now the current start flowing from both the ways. But, then the constant load current flows through the resistance and inductance connected in series, due to its large reactance.
Then a sinusoidal current flow through the LC resonant circuit to charge the capacitor with the reverse polarity. Hence, a reverse voltage appears across the Thyristor, which causes the current Ic (commutating current) to oppose the flow of the anode current IA. Therefore, due to this opposing commutating current, when the anode current is getting lesser than the holding current, Thyristor turns OFF.
The Load plays an important role, since a High Load will take away the Commutating current and prevent Thyristor commutation.
Read https://www.pcepurnia.org/wp-content/uploads/2020/03/New-Doc-04-06-2020-10.39.53.pdf
salhi
Joined Nov 29, 2023
86
Great i understand now how the commutation work superficially using words, but i want to see the équations that says this along with some interpretation of the latest current/voltage graphs i uploaded, Infinite thanks though
