AT28C16 EEPROM with 5x7 led matrix Project
Jony130
Joined Feb 17, 2009
5,599
I did the test of this circuit today with NET-74LS93
And the diode reset circuit works on my breadboard.
But the reset signal was way too short. So I was unable to capture it on the scope. And this is probably why the short reset pulse is unable to properly trigger the JK flip-flop.
q12x
Joined Sep 25, 2015
2,238
Maybe a capacitor to add, to delay it for a bit longer?
Thank you very much for showing me the data ! Very cool that you have a Rigol !
q12x
Joined Sep 25, 2015
2,238
And some big problem: - Tell me if you know about this problem and how to resolve it?
Thank you !
sarahMCML
Joined May 11, 2019
703
The clock input of the 4027 is floating, when QA,QB,QC are high.
Connect a pull-up resistor ( for example 4k7) to the clock input.
When I tried it, it didn't work, although I must admit I was using a very old CD4027AE version from RCA.
, not a more modern B suffix type. I found the following to work.
1) Remove the diode from QA and unlink the 2 R0 pins.
2) Reconnect the 2 remaining diodes, with the 4K7 pullup resistor, to 1 of the R0 pins.
3) Reconnect the QA pin to the other R0 pin with a wire link.
That effectively gets you back to the original working AND gate circuit. The problem is the reset pulse at the 8 count is so fast the CD4027 never even registers it (my one at least!)
q12x
Joined Sep 25, 2015
2,238
I remember last night when it worked, I had this arrangement from original experiment.
It was not doing anything important so I remove it today.
I start to believe it was affecting the circuit.
All the switches are turn off, and all the addr pins are pull down by those blue resistors on top near the blue DIP switch.
Ive already put resistors to gnd on each addr pin but no effect, it didnt repaired the problem.
Every voltage from (both) 7493 to addr pins are fine, it is counting fine, no problem there.
The memory IC is affected by something....
q12x
Joined Sep 25, 2015
2,238
Nevermind, problem solved - my mistake (as usual) and I find the cause. Thank you for the ideas !
q12x
Joined Sep 25, 2015
2,238
And here I am showing how to program some letters and also switch one after another.
Do take a look at this beauty: aaah
Thank you very much so far !!!
q12x
Joined Sep 25, 2015
2,238
to miss @sarahMCML
I made your circuit and it works ! Better later than never, right?
Thank you very much, miss sarahMCML, I really like it. So the answer why it did worked in simulator but not in reality was a simple wire reconfiguration.
Here is what I did and how I did it:
q12x
Joined Sep 25, 2015
2,238
to @Jony130
Your diode circuit will never switch that Clk input of the FF because ...tada, tada, that R1 will always keep it in High state. Hah. I mean, the original thought was to be a pullup resistor. But I bet the FF is seeing it as a input signal always being high. But very curious mister Proteus simulator, did switch it, even if it is always High !!! Probably for him, it is a pullup resistor...hmmm. Eh well.... we learn. At least is counting to 7 ! 50% of the job is done. Heh. We will find a smart way to solve it, Im sure of it.
sarahMCML
Joined May 11, 2019
703
to miss @sarahMCML
You must still have a slight wiring error in your circuit somewhere because on mine the last LED ( connected to QD) never turns on, which is correct.
And just our of interest for you, I didn't use a separate NAND gate IC to drive the flipflop, I used a spare AND gate from the CD4081! Saves on IC's and space!
sarahMCML
Joined May 11, 2019
703
to @Jony130
I just tried Jony130's circuit above with both the CD4027 and a 74LS74 D Type flipflop. The CD4027 doesn't work because the reset pulse is way too fast to trigger it, but the 74LS74 DOES manage to trigger properly, and switch the LED on and off.
q12x
Joined Sep 25, 2015
2,238
I just look now in my IC list and I dont have your 74LS74. But Im glad it worked, with a special FF then, that was the answer.
VERY interesting !!!! Really - thank you !
jjw
Joined Dec 24, 2013
823
to @Jony130
Don't bet too much:)
The diodes will pull the clock input low (~0.7V), when any of the outputs of 7493 is low.
sarahMCML
Joined May 11, 2019
703
If you have any Positive Edge Triggered 74LS series flipflop IC's in your list, try one of those instead of the 74LS74. Should work!
q12x
Joined Sep 25, 2015
2,238
Project finished.
I disassembled everything from the breadboards.
Target was reached.
Thank you all. What an adventure, right? Haha.
dl324
Joined Mar 30, 2015
18,454
Something I designed using a single character display:
Might have to move further away from the screen or blur your vision to see it...
I used a Raspberry Pi Zero W so the time would be set automatically once it connected to the internet.
The row drivers are on 2 boards to the left of the display. Column drivers and counter are on the board to the right.
q12x
Joined Sep 25, 2015
2,238
Very cool mister @dl324 ! I like it. I also like the horisontal scrolling effect. When did you make it?
I believe on a LONG panel the scrolling will be quite 'smart' and intelligible to watch. But on a single matrix appears too fast. But is readable, is fine. Post your circuit please. If you still have it. Or re-make it, just for me. Hehe.
And I waited too long... yes the vertical scrolling that you told me to do it.
