Arduino 12V digital input
Lucky-Luka
Joined Mar 28, 2019
181
Any reason despite being a smaller circuit, you have gone away from the opto isolator that was recommended ?
You have recommend me the opto, others have recommended me the voltage divider... As a first try I have chosen something I was more familiar with. Don't take it personal... I have said that I will try the opto solution too...
Lucky-Luka
Joined Mar 28, 2019
181
Thank you
Good luck
In this last revision I've opted for a buck module and a linear one to avoide switching noise and because I want to use this board with 12V and 15V input.
I have also used an opto to avoid the trimmer.
It should work just fine, do you agree? I will try this circuit soon.
Thanks
click_here
Joined Sep 22, 2020
548
Thanks
Double check what output pins you are using for the 4N35 opto :)
ericgibbs
Joined Jan 29, 2010
21,627
hi LL,
The original circuit post #2, will work OK.
This is a sim showing Signal from 10V thru 50v, all the parameters are well within specification.
E
Lucky-Luka
Joined Mar 28, 2019
181
hi LL,
E
Nice.
So, I see that there are at least 2 school of thought for my board.
p.s. that simulation consider the fact that input pin draws almost no current so that Zener diode can guarantee almost constat voltage, right?
ericgibbs
Joined Jan 29, 2010
21,627
hi LL,
You don't need a constant voltage on an IO input pin.
Any voltage above the Vhigh threshold of about +3V is seen as an High Input , the 4.7V Zener will hold the voltage below +5v.
E
drjohsmith
Joined Dec 13, 2021
1,667
Nice.
Two schools of thought ..
That's not bad for a public forum .
Imagine trying to design a camel ..
