Analysis of a circuit
Ian0
Joined Aug 7, 2020
13,310
This is how to get an estimation of the expected result.
Does the capacitor make a significant difference? Its impedance is 10 times that of the parallel resistor at 50Hz, so assume it doesn’t.
Next, pick a few points on the AC waveform: positive peak, zero and negative peak would be good choices.
Calculate the DC voltages at the output for those voltages.
It‘s a linear circuit, so it won’t distort the sinewave, so fill in where you would expect the sinewave to be.
That gives an approximate answer, so that when you fully analyse it, you know whether your analysis might be correct.
Missio2468
Joined Mar 18, 2022
74
Hi
Hi Ian, I have done the analysis using your method but still it does not give me the values equivalent to simulation in proteus
WBahn
Joined Mar 31, 2012
33,315
yes I know that but I am not able to solve that. Can you please tell me.
The best way for you to learn is to give it your best attempt and show your work here. That way we can see where your trouble actually is and help get you on the right path. If we just show you everything, then you will think you have it down because it will seem to make sense at the moment, but there's a really good chance that, a week from now, you still wouldn't be able to solve a similar problem on your own.
WBahn
Joined Mar 31, 2012
33,315
Hi E,
I have gone through the links but the issue is there is not a single problem which resembles to my circuit.
This gets at the root of the problem. You don't understand the fundamentals well enough to apply them to a circuit you haven't seen before, and so you are left trying to find the work of someone else that has solved a problem exactly like the one you are trying to solve. But doing so will leave you unable to deal any differently with the next circuit you see.
ericgibbs
Joined Jan 29, 2010
21,626
Hi M,
Nicely done, this sim confirms that answer.
So now try circuit #2 in this image.
E
BTW: It will help if you posted your actual calculations.
Ian0
Joined Aug 7, 2020
13,310
Hi Ian,
I have considered 498 v ac and for peak Vout across rc parallel is 1.61V, across -ve peak = -1.62V and at zero it is equal to 0.00576V
Think!
For the Vac=0 situation. The AC input is joined to the output by a big resistor. The 2.5V reference is joined to the output by a small resistor. Is the output likely to be closer to the AC input or the 2.5V reference?
If you learn how to guess the right answer, then when you calculate it you'll know whether it is right or wrong.
How much sinewave are you likely to find on the output? Something to do with the ratio of the two resistors?
ericgibbs
Joined Jan 29, 2010
21,626
Hi M,
I know that the original question had a 2.5Vdc source, but in my test circuit I set it at 5Vdc.
The full equations for both source voltages would be the same, except for the voltage source values.
Your equations are way off the mark, so you have an incorrect answer.
eg: your (va1-2.5v)/2k7
Why (va1-2.5v), can you explain why you think this is correct?
E
Missio2468
Joined Mar 18, 2022
74
Sor
Hi M,
E
I h ad 2.5V in mind but according to your circuit va1 =4.259V
Also the Va1-5/2.7k, I have used nodal analysis. Is something wrong?
