Add a down limit switch to a hoist
Jovanny-T
Joined Jun 19, 2023
Hi, I have an electric hoist trupper brand, this comes with a control and a switch that disables the ascent after a certain point, I want to add another to disable the descent.
I tried putting the switch between B and 10 but it disabled the up and made it go down if I pressed up or down.
I tried cutting the connection between A and B and leaving the switch, it continued to disable the up but if the switch was activated and I gave it down, it does disable the down.
My theory is that the capacitor should be connected between 7 and 10, to be between line and line, eliminate the terminal 5 and 11 and eliminate the connection e-a-b.
38,946
Sorry, but I don't understand your wiring diagram.
Can you explain what each of those connections are?
Where are the up and down switches?
