Please make me a circuit, how it should be.Get rid of the bridge rectifier. Circuit ground is the node between the two capacitors.
With 12VAC, you should get about about +16V and -16V.
I made how i thought it will be logical.
Thank you.
\( V_{peak} = \sqrt{2} * V_{RMS} - V_{diode}= 1.414 * 12V -0.7V= 16.27V\)i have no idea how you calculated that 16V, but here is another version that indeed give a 16V and -16V
Try adding a ground symbol to the node between the two caps so the simulator will know where your ground reference is. LTspice won't even run without a ground symbol.Ive added the V0 wire that it was supposed to stay at 0V but it is fluctuating between 12V and -12V as you can see in the image.
Not correct. Ground is used on DC power sources. This is AC.Try adding a ground symbol to the node between the two caps so the simulator will know where your ground reference is. LTspice won't even run without a ground symbol.
power source.
I do have a pretty big stock of transistors, but i dont have ALL types for sure. I only gathered what i though necesary. Also some fished from boards that now are good to go into a museum probably. (i have transistors that are marked with a blob of color, before ones with printed numbers on them) Very odd ones indeed. I also have a ton of resistors all put on categories. Also an entire set of zener diodes 30values, ranging from 2 to 39. And not so many IC's. I still have to make someday this step, in filling up all the important IC's we talked about them some years ago, if you still remember, I have put that list in a safe folder and when it will come the time, I will make use of it. But until i can be able to purchase all that list..eehee.If you don't have any transistors,
I am correct. You have to ground one side of the secondary to make a bipolar supply.Not correct. Ground is used on DC power sources. This is AC.
It's just a couple of voltage followers.though is awfully complicated.
I assumed that you understood how to generate the voltages from a transformer.your circuit assumes that i have already deal with the -xV but in fact I am still stuck at it
In general lines, I do, but in this case, with V-, i got a bit confused ,i admit.I assumed that you understood how to generate the voltages from a transformer.
If you build this circuit as shown above, NOT as you show it in message #128, it WILL work. The circuit in #128 has AC voltage applied directly across 2 electrolytic capacitors, because the diodes are in the wrong places in the circuit. Try modifying your hardware and try it out!Not correct. Ground is used on DC power sources. This is AC. View attachment 217993 power source.
If you pay more attention, I have there an AC power source. Adding diodes it will swing from + to - and from - to + , 50 times per second. So... in the eyes of a simulator, my AC is still a power source and it is functioning fine on my PC. It should function fine in LTspice as well. Make a test and will thank me later. You must pay more attention, it happens to me too, no problem.
I also love your new circuit you made there with the 2 opamps, though is awfully complicated. It is pushing forward my understanding and familiarity of the opamp , thanks to you, so i thank you ! Its very good. Im more a practical man, and i tend to simplify to the basics. :] Your new approach is very exciting to me.
- But I cant understand its usage. Until now, practically/in reality, i can not obtain -12V from my transformer. I did obtaining it, only in simulator, and that gives me som stange results : higher voltage, 16 or 24V above my normal 12 that my transformer is giving at the moment.
So... your circuit assumes that i have already deal with the -xV but in fact I am still stuck at it: View attachment 217992
I already (also thanks to your older circuit) compile a workable solution but i dont completely like it
Yes, I was testing a lot of permutations. I also observed that the polarized capacitors are directly on the AC line. but as you see from the video, the diodes are on the breadboard in testing phase. Now, I put them correctly, before the capacitors and also change them as 100uF as you suggested. Now is showing correctly, +7V and -7V on both ends, relative to the ground. The total sum, if i measure directly V+ and V- it gives me 13.xxV.You made a dangerous error with the capacitors and diodes. The polarized capacitors have AC across them instead of filtering the rectified AC. also, the value of 10uF is too low, use 100uF instead for better filtering and 8V instead of 6V with a lot of ripple.
We usually take measurements with respect to ground.I also tested on the opamp and is giving me +2V at output instead of -xV, measuring from V- to output; while I power it from V+ and V- of the power source. If I measure from V+ and output, it gives me +11.xxV
well, in this case, as you observed already, I dont mention much about ground, because its easy!! but is wrong in this configuration, where we have this V- element which is lower than ground ! We actually dont have any ground in my opamp circuit, only a higher than 0 voltage , which is V+ and a lower than 0 voltage, which is V-. But no actual 0V or ground - inside this opamp circuit.We usually take measurements with respect to ground.
You can use the ground from the power supply.We actually dont have any ground in my opamp circuit
There's so much wrong with that circuit.Here is the opamp circuit that I have on the test board
My opamp that i curently have (20pcs because they were cheap) is uA741. And is also the only opamp model i have. I will buy other newer ones as you all suggested to me and i trust you, but... i dont have that much money, especially as an artist.When the opamp is rali-to-rail output, you should expect an output voltage of - 7 Volts.
What opamp is used in the simulation?
An 741 will not get down to - 7 Volts.
Are you certain the opamps are good? Cheap doesn't imply functional. If you bought them from Amazon, eBay, or anyplace in China, they're likely counterfeit, salvaged, and/or rejects.My opamp that i curently have (20pcs because they were cheap) is uA741
I cant argue with you at this point. I certainly must make a circuit tester for my opamps functionality.Are you certain the opamps are good?
Noninverting opamp AC performance | PCB Layout , EDA & Simulations | 17 | |
OpAmps in parallel | General Electronics Chat | 21 | |
Opamp gain-of-5 stability resistor | General Electronics Chat | 26 | |
Correct means to lower/set input impedance of parallel opamp inputs? | Analog & Mixed-Signal Design | 12 | |
Opamp gain calculation | Homework Help | 22 |
