About opamp.
dl324
Joined Mar 30, 2015
18,524
The blue ones are just impossible to read, 1 because the contrast is very bad between colors and 2 because the very different coloring system they have for 5bands, than the classic easy to remember coloring 4bands and 3 because the lines are absolutly equaly distanced and you will have no idea where is the head and where is the tail of the color bands reading.
Since the tolerance band is brown, you only need to worry about which end to start reading from for resistor values that start with 1. If you have some 2% values, then you'd also need to worry about values starting with 2.
