About bench power supply
Status
Not open for further replies.
atferrari
Joined Jan 6, 2004
5,012
Can anybody donate me a power supply. Doesn't matter if it is used and old. Kindly tell me if you have.Its really help for me.Thank you.
It seems that you aim high (nothing wrong with that) as per the image you posted. :)
I would try to build two fixed voltages PSUs for 12V and 5V output. Retrieving 3-terminal regulators from old equipment is not an impossible task. Could you recognize them?
Once you have them finished I would go for a variable one (adjustable I mean) based on an LM317. Before you ask about it, please read on the Web.
saliyawickramasinghe
Joined Feb 13, 2019
27
Thank you atferrari. I will try to build one. I think it will enough for me.
MaxHeadRoom
Joined Jul 18, 2013
30,661
Thanks Max.How could I do it with low cost? Please help me.
Not sure how much opportunity you have in Sri Lanka for scrap parts, but look for any electronics that is on the heavy side, it will often have a linear power transformer supply in it, even if the voltages are not what you need, you can usually modify the secondary winding's to suit.
This is what I did once long ago when I built a valve tester.
Max.
Joined Feb 13, 2019
27
Max.
My expectation is to get 0-30 V and 0-10 A. Now I have an idea how I can build it my own. It's really feeling self satisfaction for me building a one my own than getting a ready made one.
38,507
10A is is pretty big supply and you don't often need that much for general electronics work.
Starting with an old laptop supply, as suggested by Wendy, is a good place to start if you can find one at a thrift store.
They are efficient, and typically output 2-4A at around 19Vdc, depending upon their power rating.
You could use one or more LM317 adjustable regulators, to generate the desired output voltage(s).
They are simple to use, and are very rugged, with built-in short-circuit and over-temperature protection.
The have a minimum output voltage of 1.2V, but that's sufficient for most experimental purposes.
Joined Feb 13, 2019
27
Thanks crutschow. I'm working on it. yes 30V is not need yet.But I have planned for future purposes too.
Status
