What is a good source for bench power supply cables
ajoeiam
Joined Mar 26, 2022
19
Greetings
Its in transit but I have an older bench power supply coming. (No cables included!)
Tried looking in mr jeff's emporium, fleabay and ms ali's- - - - 'bench power supply leads' just doesn't get me anything useful.
What search term(s) should I be using?
Favorite supplier(s)?
TIA
Ya’akov
Joined Jan 27, 2019
10,307
Welcome to AAC.
This Amazon search is a start. You are looking for “test leads” with “banana plugs” and whatever sort of “clips” you would like. The term “power supply” is also a helpful addition.
Be sure you figure out what ampacity you will need, and consider that micrograbber style clips and larger alligator clips serve different purposes and having a range is a good thing.
ajoeiam
Joined Mar 26, 2022
19
Welcome to AAC.
What is the term for the leads that one puts between the knob and the back plate on the post?
(Hopefully my explanation makes sense!)
TIA
35,199
The terminals are called banana posts.
The connectors that are fastened behind the posts are called spade or fork connectors.
I don't bother with the spade connectors. I simply use 16-18 AWG stranded cable and wire up with banana plugs to make my own cables.
Plain alligator clips will fit nicely on the plugs when you just need to clip on to something.
As for a supplier, I have never purchased online from this store. I just walk in. It says free shipping for orders over $100.
https://shop.sayal.com/
I was there yesterday and bought this circuit board holder for $10. It was surprisingly very well made.
bassbindevil
Joined Jan 23, 2014
924
If you want nice quality test leads, then Johnson or Pomona banana plugs and Mueller alligator clips are the way to go. Although, since Mueller isn't making clips in the USA any more, I'm buying Pico alligator clips from the autoparts store.
The flexible stranded wire used for harnesses on equipment like manlifts makes great test lead wire, if you can scrounge a length of that somehow; it comes as a wide multi-conductor zip cord in a protective jacket.
